    Mar 23 2008
    philippines
    h&r springs question
    hey guys need some information. i have H&R sport springs that i want to install on my car. i have 18" rs4 reps on them right now and i was just wondering if i would have to roll my fenders? will the tyres rub? the size says 18x8 with 112 pcd (whatever that means). pardon my ignorance people! thanks!
    Registered Member Two Rings nyca4tq's Avatar
    Mar 14 2008
    Re: h&r springs question
    Tire size, rim offset and current vehicle height are all factors. There is a lot of info on here about your question, do a search.
    F N G here....
    Everything is relative.
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    112 is the bolt pattern. 5x112.
    most 18X8 reps are 35-40 ET. which will fit fine without rubbing as long as you arent on adjustable bilsteins. i think they may rub on the lowest setting.
    Mar 23 2008
    philippines
    great thanks for the info!
    Veteran Member Four Rings Tifun's Avatar
    Jun 21 2007
    99.5 A4, 08 Mazda3
    Indianapolis Indiana
    My RS4 reps have an ET of 30. I'm on H&R springs. I had to roll my fenders. I still rub from time to time, usually on fast turns and dips in the road. It's not bad and doesn't happen all the time. At least once a day I will rub. Also I only rub in front.
