Results 1 to 15 of 15
    Active Member Two Rings Turbo PKW's Avatar
    Jan 22 2008
    05'A4 Avant Q USP+09'VW Touran
    Germany
    Unhappy I think I bought the wrong I-pod interface[:/]
    I bought the Dice electronics i-Audi R kit
    I own a 05 A4 Avant with audi symphony radio with integrated 6 disc changer.
    All the connections work but I don't get a charge on the I-pod nor do I know how to get it to work.
    Am I doing something wrong?
    How do I know if I have a fiber optic audi vehicle?
    I would post a pic of the kit but I dont know how to.
    Ich Bin zurÜck im Deutschland!
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: I think I bought the wrong I-pod interface[:/]
    That's what I ordered - mine gets here tomorrow. I also have the in-dash changer. I'm pretty sure I did the proper research, and that's the right part. The only other one was for the glove box changer.
    The instructions seem a little complicated, but I ran into several good posts on this forum - try searching for i-Audi-R. Also, there's a YouTube video of Enfig showing how it works.
    Not sure why it wouldn't be charging though. What kind of iPod is it?
    Jan 22 2008
    Germany
    Quote Originally Posted by kwimberly View Post
    I-pod classic 80G
    I will hold on to it, let me know if you have any luck with yours.
    Can you send me an install link if you find one.
    Thanks
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    One thing about those interfaces that I noticed is need of grounding. The two interfaces for symphony that I used had special wire that was ground and had to be connected to the HU in order to work properly. That could be the problem.
    May 03 2008
    Orlando
    This is the Dice install doc: http://support.diceelectronics.com/f...di_install.pdf
    I'm going to try to get mine installed soon, but I graduate from law school this weekend, and my family is coming in. Also, I'm using the AUX on the Dice to hook up an XM receiver, so I have a little bit of work to do in running the antenna, splicing in a new cigarette adapter to power the XM receiver, etc. Study for the Bar exam... Install stereo... Decisions!
    May 03 2008
    Orlando
    Quote Originally Posted by T0M3K View Post
    I noticed a lot of threads where proper grounding ended up resolving the issue. Check out Step 6 in the install document.
    Oct 31 2006
    San Antonio, TX
    http://a4mods.com/index.php?page=web...s/icelink.html
    Not exactly the same thing but it might help...
    Current: 2016 S6 Previous: 2015 A6, 2012 Q7 Prestige SLine, 2005 S4, 2007 Avant 2.0T, 2002 A4 1.8T
    Jan 22 2008
    Germany
    I found a thread where someone mentions a 2nd cd changer hook-up in the glove box.
    I PM'd the guy Ill see what he says.
    Dec 18 2006
    03 A4 1.8t | 04 IB M3 SMG
    Hanover, NH
    I installed mine in 3 minutes about 2 years ago ... pm me if you need help
    1) You need to ground correctly or you hear static
    2) It wont' charge certain ipods
    3) YOu need the correct harness - if they gave you the wrogn harness it wont work
    Now: RNS-E | Debadged | GIAC 1+
    Soon: Caractere front and sides | S4 Rear | S4 Doorblades | Bi-Xenon E-Codes
    Future: GTRS BT Kit | Tip Tranny upgrade for BT Kit
    Veteran Member Three Rings RASTA4's Avatar
    Feb 26 2005
    2002 A4 3.0
    Metro Detroit
    I installed mine over the weekend w/o any glitches. You never answered the question about connecting the ground wire. You also didn't mention whether or not you have a glove box CD changer as that setup requires a different dice harness, iirc
    |2002 3.0 SEDAN Q6MT|POLAR WHITE|PLATINUM BUFFALINO|SPORT|CONVENIENCE|COLD|BOSE|BNS-NAV|PARKTRONIC|SUNSHADES|ODO=34XXX|
    MODS
    |PES G3 SC|SUPERSPRINT|AFE PRO-DRY|18x8 BBS RE-G FORCE SPORT|17x8 BBS RC-CONTIEXTREME|H-SPORT S4 SWAYS|AMS SS|APR SNUB|STOPTECH 332 FRONT-BREMBO X-DRILLED REAR|HAWK HPS|SS LINES|OPTIMA-REDTOP35|XENON ECODES|LED CITYLIGHTS|HOEN|SYMPHONY II+|DICE|35% SOLAR GARD|S4 DOOR FLARES|MOTUL 5.1|MOBIL 1 0W40|
    May 03 2008
    Orlando
    I just installed mine - works like a champ. I set the switches to simple mode. It's cool because I still have the use of the in-dash CD changer. When I pick "CD," the changer functions normally. When I pick "CDC" I get the Dice unit and iPod.
    The only thing I'm concerned about is that the cable is smashed in between the dash trim and the bottom edge of the radio - I had to push the radio in pretty tight. I hope it's not putting too much pressure on it. I ran it right below the radio on the right side. The iPod is just sitting on the ashtray door until I pick a better cable routing option.
    The sound is SO much better than the CD player. I don't know why, but CD's have always sounded pretty much like ass. The iPod sounds almost as good as the Alpine 9856 with upgraded speakers that I had in my Jetta.
    Didn't need the radio code, and I did disconnect the battery.
    Dec 18 2006
    Hanover, NH
    umm take ur radio out again - this time slide the cable out of the boot of the side and pull it out the back
    OR
    pull it through ur globe compartment - it just plain looks better
    to have the cable come out under the radio is hella ghetto
    Mine comes out the bottom of that piece on the side that covers the center console
    i used to have it come out of the glove box as i had my ipod in there
    May 03 2008
    Orlando
    Quote Originally Posted by 47Ronin View Post
    That's why I said it was temporary! I had stuff to do last night - just wanted to throw it in there so I could reply to the original poster. Will reroute tonight or tomorrow night.
    edit: I also went ahead and installed the panavise mount for my XM receiver.
    This is how I had my old Jetta and old XM receiver. I know - still kinda ghetto. I ran a new cigarette adapter behind the dash via an add-a-circuit. I have to treat the Audi better...
    Active Member One Ring heath22's Avatar
    Oct 19 2007
    Atlanta GA
    Quote Originally Posted by Turbo PKW View Post
    Where did you get this and how much was it?
    2004 1.8T QMT USP
    Dec 18 2006
    Hanover, NH
    ur arness is wrong
