Results 1 to 4 of 4
Thread: Offset
    Senior Member Three Rings PMR2.7t's Avatar
    Mar 26 2008
    2003 A6 2.7T
    Harwood Heights, IL
    Offset
    Need some help im buying some RS6 18" 5spoke replicas. what dose the off set mean 40mm 30mm ???????
    And which one is the best for 03 A6 2.7
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: Offset
    Most of our 18x8 are ET35, 40mm may be just a little too close to the strut depending on the wheel.
    Jun 14 2005
    Anaheim, CA
    Re: Offset
    Just like Doc said, a 8" wide wheel with a +40mm offset might look slightly sunken in and could possibly rub the inside strut or suspension arms.
    -Charles@VMRWheels
    Brandon @ VMR Wheels
    Mar 26 2008
    2003 A6 2.7T
    Harwood Heights, IL
    Re: Offset
    Thanks for the help im buying RS6 replica 18"8.5 30mm offset/.
    I only want to know will a 255/40/18 tire rub ?????? or should i stick with 245/40/18??
