Results 1 to 12 of 12
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    ***PSA*** Check your dipstick tubes
    While changing my oil today I realized that the base of my dipstick tube, basically where it attaches to the block was broken off. I was leaking a decent amount of oil it seems but it never was visible from up top or below the car due to the belly pan. So next time your out looking at your engine, just take a little glance at your dipstick tube.
    Some fast things and some slow things
    ~Josh~
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Re: ***PSA*** Check your dipstick tubes
    mine broke 2 days agao when i was doing my intake manifold install.... ordered a new one from purems for like 5 bucks
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Dec 06 2007
    mine had broken too fix it or else!! i had some oil leak problems until i changed the base, and the new base is much sturdier!
    -Kirk
    BetaAlphaTau Member #58
    Feb 17 2005
    Sarasota, FL
    Yea those things are brittle POS's!!! I broke mine when I did my bottom end, luckly they are only like 8 bucks from the dealer
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    That's funny - that brittle orange plastic POS holder is what pushed me over the edge to trade in my Jetta for the A4 earlier this month! I checked my oil, and it cracked in several places. Drove to Full Throttle VW, Shannon popped a new one in, then I traded it in the next day.
    Feb 17 2005
    Sarasota, FL
    OEM Part # 06B 103 663G if anyone wants/needs to know
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by mtbrider View Post
    Josh,
    Are you referring to the metal bottom half of the dipstick tube? Its pressed into the block (not easy to remove). The upper half is the orange plastic POS (gonna replace mine when I put the 2.0 in) that winds up cracking. The other piece that cracks is where the dipstick meets the orange handle.
    -Doug
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    Thank you sir.
    Quote Originally Posted by A4ringedONE8T View Post
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Mine cracked when i replaced my thermostat.
    Bought a new one and for some damn reason it doesnt clip into place...If I try to pull up on the dipstick to check the oil, the whole damn funnel comes up with it! I ghetto rigged it with some woodscrews to hold it in place but need to replace it...even though it is brand new
    -Sami-
    Oct 31 2005
    Virginia
    Josh,
    Its the plastic portion.
    ~Josh~
    Veteran Member Four Rings Charles's Avatar
    Jacksonville
    My dealer tried to charge me 80 bucks to replace mine. I literally couldn't hold back the laughter.
    I was like, so that's what, 10 bucks for the part and an hour of labor to simply insert it back into the tube??
    Oct 29 2005
    10speed
    San Francisco, CA
    lol mine does the same thing... I just push down on the plastic piece when I pull the dipstick up for the first time and its fine
    - Clint
