Results 1 to 3 of 3
Thread: tire shaving
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    tire shaving
    i thought i heard somewhere that if you need 1 tire, you can get the tread shaved on a brand new tire so that it somewhat matches the other 3 tires. does anyone know where you can get that done? thanks.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Senior Member Two Rings [IX]'s Avatar
    Mar 09 2008
    Florida
    Re: tire shaving
    Tire Shaving...what?
    KDW FTW
    <<NO SIG>>
    Veteran Member Four Rings 3ohAvant's Avatar
    Mar 10 2004
    east bay, CA
    Re: tire shaving
    tire rack does tire shaving. most race shops do that as well.
    its not normally for this purpose, but to get a tire down to a race tread depth.
    basically you cut off 1/2 or more of the tread of a new tire because a typical treaded tire will "die" before it gets corded. By die, i mean that though enough heat cycles, it will no longer be sticky enough for ones tastes. So you shave a tire down to get less squirm and so that you wear out the tire in sequence with the tread wearing itself out.
    - Benny
