All parts removed from Engine code: AEB
Great parts for someone rebuilding their engine or someone that just wants to just cleanup their engine bay. These powder coated parts were degreased, sandblasted, and metal washed before coating.
Powder coated pulleys, tensioner bracket, damper + dark graphite grey color - $45
Powder coated oil pan – wrinkle black color - $45
Powder coated accessory brackets – wrinkle black color - $25
Coolant and PCV steel tubes - $20
Head – Sold
Throttle Body - $35
Engine block -$120 (pickup only please)
Transmission – 5 speed, no differential, 1 bad bearing, perfect for parts - $60
Transmission – 5 speed - Sold
Crankshaft w/speed sensor ring - $60
Alternator - Bosch with less than <10K miles - sold
Forged connecting rods (large size wrist pins) - $80
02 Sensor <10K miles - $15
Starter - $25
Fuel rail with stock injectors, fuel pressure regulator - $25
Knock sensor - $15
Crankshaft sensor - $15
Air intake sensor - $15
Stainless turbo oil drain line - $15
Camshaft sensor - $20
Oil dipstick - $10
Pistons w/wrist pins
Throttle position sensor - $20
1.8L 5 speed differential - Sold
Timing Belt tensioner <10K miles- $20
Power Steering Pump
CV axle - $25
Oil pump/pickup - $20
Brackets - Engine block to engine mounts - $10
Located in Ypsilanti, MI. Any questions, just ask and I'll be happy to answer them!
