Results 1 to 7 of 7
Thread: Batteries???
    Registered Member Three Rings
    Sep 17 2006
    05 Ford Escape XLT, 07 Corolla
    Springfield, MA
    Batteries???
    So everytime I leave my car for more than 48 hours without driving it, the car won't start. I took it to my mechanic and he checked to see if there were any draws, nothing. He tested the altenator...nothing. So tonight he is checking the battery. The only reason he didn't do that first is because the battery is 2 months old. The battery is a cheapo from Autozone.
    Can anyone else think of anything else it might be?
    Honestly, I just need it to run for 2 more weeks. I am closing on my house on Wednesday of next week and then I am trading the car in.
    Thanks for the help in advance.
    Veteran Member Four Rings trueno429's Avatar
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    Re: Batteries???
    are your battery terminals tightened fully? if they're loose they might be the problem
    Sep 17 2006
    Springfield, MA
    Re: Batteries???
    Hmmmm...never checked that simple thing. They are throwing a new battery in it tonight and hopefully they will tighten the terminals.
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    Re: Batteries???
    I noticed that everyone is usually checking for voltage drop, but I wonder if connecting amp-meter will yield better result of battery drain. But anyway, my guess is that battery just doesn't hold charge internally and dissipates it also internally. Recall battery.
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    Re: Batteries???
    Well there are a few things you can do a test on.
    Battery Load test
    Static Voltage test (just having dirt and water on top of battery could help drain it)
    get a hydrometer and test the electrolytes....or even make sure there is water in there :)
    Alternator test, make sure it is drawing the correct amount of amperage with car on and all accessories on.
    there are quite a few test...if you need any more help let me know.
    a DMM will do most of the test, except for a load test and some others you will need a VAT
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Active Member Two Rings B-Rob's Avatar
    Mar 13 2008
    Bellevue, WA
    Re: Batteries???
    Quote Originally Posted by SinisterA4 View Post
    Corrosion is a common one, too. Always worth checking the simple stuff first.
    '03 A4 3.0 quattro, dolphin gray on ebony
    Sep 17 2006
    Springfield, MA
    Re: Batteries???
    Quote Originally Posted by Audi Skate Snow View Post
    Battery Load test
    Thanks for the input. I get the car back with a new battery and we will see what will happen. We tested the altenator already with and without accessories and that came out good. I am hoping that this is a recall battery and that the new higher quality one will help. I shouldnt have been so cheap.
