Results 1 to 4 of 4
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Honking from airbox at idle...
    Hey guys, I am getting a honking noise, almost like wind over a bottle when my car is running at idle... I just changed out my PCV system but it isn't comming from around that area... It comes out of the airbox vents. I just changed my puck valve because when I took it off for the PCV clean/change, the diaphram came out in peices... Crumbled out. After changing that, it still did it... Any ideas? Also loosing a little boost... I though DV's only honked while under boost?
    ΜΟΛΩΝ ΛΑΒΕ
    Mar 04 2007
    nothing
    nowhere
    Re: Honking from airbox at idle...
    Tested the bypass valve... At least it still hold vacuum?! Dunno about boost though...
    ΜΟΛΩΝ ΛΑΒΕ
    Veteran Member Four Rings audiFUEGO's Avatar
    Jul 17 2007
    2001.5 A4 1.8t QM
    Boca Raton, FL
    mine whines like that too.... ever since i changed the suction pump.
    Mar 04 2007
    nothing
    nowhere
    Hmmmm, I will double check that... It is kind of annoying... Did it ever go away? Also, I put my ear up to a screw driver then up to the suction pump to help locate the noise and it didn't seem to come from there... I think it was making the sound before I changed that too... I mean, the sound is comming right OUT of the airbox openings... Which leads me to beleive it is the DV/Pressure Reg Valve or maybe even the N75?
    ΜΟΛΩΝ ΛΑΒΕ
