Results 1 to 11 of 11
    Veteran Member Three Rings awdbiturbo's Avatar
    Apr 20 2004
    01.5 S4 /95.5 URS6/72 914/
    Boston
    JHM shift linkage upgrade BT: How hard is it to install it while the tranny is in the
    car? TIA ~Rob
    2001 Audi S4 Stage 3+/996TT with mods/HURACAN LP610-4 VORSTEINER NOVITEC VF ENGINEERING / 22 AUDI RSQ8 NARDO CARBON/22 RS6 NARDO BLACK OPTICS IE EVENTURI CTS
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Re: JHM shift linkage upgrade BT: How hard is it to install it while the tranny is in
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Apr 20 2004
    Boston
    If you noticed that video was shot with the trannt out and on the ground. My question was "How hard is it to install it while the tranny is in the car?"
    Registered Member Three Rings YMJ's Avatar
    Feb 08 2008
    2001 Pearl White Audi S4
    apparantly you cant.. but im not an expert..
    Pearl White B5 S4
    APR Chip~APR Exhaust~APR boost Gauge
    Bosch 710N DVs
    Koni Sport Shocks~Eibach Springs
    JHM Short Shift Kit~Bimmian Titanium Shift Knob
    RS4 Grill
    18'' RS4 Hyper Black Rims
    Interior Xenon Kit ~ 10 K HID Kit
    FREE 10SecS4!!
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Quote Originally Posted by awdbiturbo View Post
    Sorry, for some reason I though it was the one where he installed it in car.
    Here's a quote I dug up:
    Quote Originally Posted by jaybquick@JHM
    Just like the stabilizer bushing, It is easiset to do this mod while the tranny or engine is out for major upgrades. However I have done this mod on the ground with a floor jack. Personally I can do it in 3 to 4 hours (without a lift) including the time of installing the mod into the shaft. You just need to unbolt the back of the engine support and depending on your DPs, you may have to remove them. I can do it without DP removal on APR DPs and most other aftermarket. The stock are hard since they don't have a flange near the tranny and they are long
    Lots 'o Goodies
    Dec 06 2007
    Calgary, AB, Canada
    Driver's side dp off, axle and axle heat shield off, and you can access it alright.
    Apr 20 2004
    Boston
    Quote Originally Posted by The_Jerbel View Post
    You can remove it without taking the dp axle off....Just the axle heat sheild and the wheel has to be removed.
    Dec 06 2007
    Calgary, AB, Canada
    To tell you the truth, the wheel doesn't even have to come off. I can't even see it being possible to do the mod without taking off the dp and axle, unless you're houdini...
    Mar 20 2008
    Italy
    In that video Jay modifies the shifter brace by cutting it a little on the edge.
    ARE YOU SURE it can be done with the brace in place?
    Thanks
    Apr 20 2004
    Boston
    Quote Originally Posted by andream88 View Post
    Thanks
    are you serious? The shift linkage has to come off the tranny. What i am saying is that i have it out as we speak and only to the axle heat sheild and the wheel off
    Dec 06 2007
    Calgary, AB, Canada
    Getting the stock linkage out is easy, installing the solid linkage is the hard part. I would never try it with the axle (and probably the dp as well) still in the car.
