Results 1 to 4 of 4
    Registered Member Two Rings nyca4tq's Avatar
    Mar 14 2008
    Do I need hub centric rings?
    I have ADR 18 x 8.5 et35 5x112
    tires are Kuhmo ecsta 225 40 18
    I cant get the vibrations to go away after balancing x 2, allignment x 2. Car is not lowered.
    F N G here....
    Everything is relative.
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: Do I need hub centric rings?
    You need to check with ADR to see what your wheels are bored to. If they're not at 57mm, then you have to have rings
    Jun 14 2005
    Anaheim, CA
    Do what Doc just recommended. Check if your hub is correct at 57.1, if not then your going to need a hub centric ring.
    -Charles@VMRWheels
    Brandon @ VMR Wheels
    Mar 14 2008
    Thanks, just fired off a question to ADR, will let you know the answer.
    F N G here....
