Results 1 to 14 of 14
    Jan 17 2008
    louisville
    WTF!? s4 ate it tonight
    so something rediculous happened to the s4 tonight. driving with my apr program on, just cruising no boost at all and I just see the tach drop to zero. big oil light came on for a second, battery light came and stayed on and my CEL that was on went off. Car wouldnt start again for like 15 minutes, finally, my CEL came back on and the car started for like 5 seconds and then died again. I tried changing back to stock and it was showing no reaction at all. I unplugged the battery for 10 and connected it again and it started and was able to make it the .5 miles home before it died again in my parking lot. During the short ride home, it would only hit 5 lbs of boost, and the gas gauge was fluctuating. I know it has gas because I just filled up today. Do you all think my ECU is shot??? i'm freaking out. I just want to sell my car :(
    Active Member Four Rings
    Dec 11 2006
    Boston
    Re: WTF!? s4 ate it tonight
    well I have the same issues when one of my intercooler pipes comes off. You could have a massive boost leak.
    Stage 3+ RS6's
    Jan 17 2008
    louisville
    but why would it do it when i was just cruising at 30 mph. and it hit 5lbs on the way home when i was testing it. i noticed in the past few weeks when i put it to stock from my CC that it hit 5 too. but with apr it hit 15-16
    Dec 11 2006
    Boston
    Good point. If you think it is your ECU. Swap out ecu's with someone local.
    From past experiences when having intercooler/massive leak issues the car will die... all lights come on, obviously no boost. If I turn the car back on right after, without fixing the leak, it will crank, idle for 10 seconds then die.
    Stage 3+ RS6's
    Apr 14 2007
    Wheeling, Illinois
    Check your alternator/battery first...
    Jan 17 2008
    louisville
    subs would still play after, read 14v. Apparently the hardchipped APR chip fucked up my ECU my mechanic said.
    Account Terminated Four Rings
    Nov 30 2006
    01.5 pearl white S4 6speed
    annapolis, maryland
    sounds like a bad ECU.. def. something electrical. Nothing mechanical
    Senior Member Three Rings rcjustin's Avatar
    Aug 29 2007
    00 s4
    karma
    Silver SSP Stage 3+ S4
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    any codes?
    Registered Member Two Rings tristate_s4's Avatar
    Dec 20 2006
    01 audi S4,93 corrado 97 jetta
    SNJ
    had a similar problem with my apr code, turned out the chip module went bad, and apr replaced it under warranty.just cost me the price of shipping.
    i was lucky someone loaned me their spare ecu for a few days.
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    Quote Originally Posted by Dr.Duct View Post
    Yeap agreed.
    Jan 17 2008
    louisville
    Quote Originally Posted by rcjustin View Post
    karma
    karma because you sold me and ECU you knew was bad!?!?! STFU man. i should have just returned it to you instead of paying to get it redone then having it mess up on me. I can't believe you would say something like that. If you really want to get into it I can tell the story here and post the Pm's from 2 users that said sorry but i got screwed because they knew the ECU was bad before I even go it. So this is the second time around of me fixing it
    Jul 17 2004
    If you saw an oil light check your level to be safe ...
    Alex
    2001.5 Nogaro Blue S4, 6-Speed, ARD 2.7T 68mm HTA GT2868 Kit
    Jan 17 2008
    louisville
    that was the first thing i did. It eally freaked me out at first because I had just changed my oil last week. but im always parked in my spot at work or my spot at home. If it was leaking, I'm sure i would have noticed some of 6 1/2 quarts lol. Butttt I did check to make sure and it was fine
