Results 1 to 7 of 7
Thread: new oil pan
    Established Member Two Rings kmoney's Avatar
    May 11 2008
    2000 audi s4
    new oil pan
    i own a 1998 audi a4 2.8Q and i recently bought a new oil pan since i put a hole in my other one, when i got the oil pan it had no gasket so i called in to the local vw dealership and asked if they had any gaskets for my oil pan and they said that audi a4's dont need gaskets and they just use a special silicone sealant but when i took off my old oil pan i saw that it had a gasket and no sealant, ive seen gaskets for my oil pan should i just order one and do i just put that on there or do i put sealant somewhere on the gasket. thanks
    Veteran Member Four Rings tamadrumr88's Avatar
    Nov 03 2006
    lehigh valley pa
    Re: new oil pan
    buy yourself a bentley repair manual, i believe it calls for an rtv gasket... its poured from a tube
    when i did the oil pan on my other car i believe i just had to make a circle around all of the oil pain bolt holes, and then obviously around the entire outer edge of the pan
    kinda like this:
    May 11 2008
    2000 audi s4
    Re: new oil pan
    so you're saying if i just get the rtv sealant i dont need to buy a new gasket and can just use that?
    Registered Member Two Rings manufan's Avatar
    Nov 16 2007
    98 A4 2.8 QM 93 Ducati 900ss
    northern pa
    May 11 2008
    2000 audi s4
    Re: new oil pan
    how long does rtv sealant take to dry before i can put oil in
    Veteran Member Three Rings black00A4's Avatar
    Oct 19 2006
    Ontario, Canada
    Re: new oil pan
    I changed the oil pan on my 2.8 aswell, no gasket just use a gasket maker.
    2000 Audi A4 2.8L Quattro Sport - Volcano Black
    Mods: 18" A8 Rep's, Ebay SS & Strut tower bar, PureMS Snub mount, K&N, MAF de-screened, H&R sports, STERN power ring & diff mounts, Cupra Lip, DEPO ecodes, Unitronic flashed ECU, Magnaflow
    Veteran Member Three Rings generik777's Avatar
    May 12 2007
    1998.5 A4 2.8 Quattro Tip
    MN
    Re: new oil pan
    Quote Originally Posted by black00A4 View Post
    Same here.
