Results 1 to 8 of 8
Thread: vag-com cable
    Senior Member Three Rings golovemd's Avatar
    Apr 12 2008
    2002 Audi A6 2.7t 6spd
    Connecticut
    vag-com cable
    Is this all I need, along with the downloaded software to tweak my 02 a6?
    http://cgi.ebay.com/ebaymotors/USB-K...spagenameZWDVW
    Feb 01 2008
    Missouri
    Re: vag-com cable
    Yeah, the ebay cable is a good idea if all you want to do is the window mods/tip mod, but the full version is needed to do the other stuff.
    Apr 12 2008
    Connecticut
    Re: vag-com cable
    Quote Originally Posted by trapped View Post
    Well I definitely don't think I want to do the tip mod on my car. Can you use this cable to pull up codes on the computer instead of getting one of those vag-com readers?
    Feb 01 2008
    Missouri
    Re: vag-com cable
    I am fairly certin that when you plug it in it will tell you some way or another. I did the tip recode and it showed the codes I was throwing...
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Re: vag-com cable
    You can find ways to turn the free 409.1 into a registered full version. That's what I do with my ebay cable. Does everything and never had a problem. You should do the Tip recode. I think the car drives much better now with it.
    Must find VAG crack....
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Apr 12 2008
    Connecticut
    Re: vag-com cable
    Quote Originally Posted by Stampy View Post
    I don't think so, I have a 6 speed
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Re: vag-com cable
    Yeah, that would make sense
    Village Idiot!!!
    (\__/)
    (")_(")
    Senior Member Three Rings massboykie's Avatar
    Mar 14 2008
    '16 Audi S6, '16 Audi S5 Cab.
    Natick, MA
    Re: vag-com cable
    I bought one of these for a family friend. I have a real VAG-COM and we could do most of what we needed with the generic cable. The only trouble is that the shareware version does not show you more than a couple of codes. Well it does, but only the code not explanation etc. It still works though, don't get me wrong. You also cannot do adaption (change settings on the car etc) with the generic cable and unregistered VAG-COM software.
    If you buy the eBay cable with the intent to register the software ($100) I would suggest spending the extra money and buying the real thing. Ross-tech only supports V4 with the generic cables so you won't get any of the new features etc.
    Just something to keep in mind
    Cheers
    Massboykie
    2016 Audi S5 Cab. - ECS Intake, K&N DI
    2016 Audi S6 - K&N DI, 10mm VCDS drop+12mm Spacers, Disc Italia+HPS 5.0
    Not to be forgotten...
    2016 Audi A3 2.0T, 2006 Audi A4 Avant 2.0T, 2002 Audi A6 2.7T, MKIV VR6 GTI & GLI, MKIII GLX & GL Jettas
    http://www.VAGLinks.com - 2000+ VAG Links!
    http://www.PlanetVAG.com - VAG Only Search Engine!
