Thread: Engine Wash
    Senior Member Three Rings PMR2.7t's Avatar
    Mar 26 2008
    2003 A6 2.7T
    Harwood Heights, IL
    Engine Wash
    Ok Guys i need to wash my engine on my 03 A6 is there a safe way to wash it???? Or just spray some water and your done .....
    Veteran Member Four Rings white fish's Avatar
    Feb 21 2004
    05 allroad(old) 10 Q5 10 S4 13 S6
    T.O.
    Re: Engine Wash
    that what I do
    just try and avoid the the coil packs and wire/fuse box
    and start the engine and leave it running for at least 15 min after yuor done
    Senior Member Three Rings skiroad'r's Avatar
    Apr 21 2008
    2002 allroad Tip, 2005 Mazda 6 Wagon 5MT
    Central New Jersey
    Re: Engine Wash
    defintiely stay away from coil packs and other electronics. I would say use water sparingly and do not use Simple Green -- it corrodes aluminuim. Oh and do not spray cold water on a hot engine.
    '02 allroad 2.7T Tip
    ASP Flash, 034 Snub Mount (DIY), VAST EFK (DIY), H-SPORTS (Hard)
    Anrott Gen II Front Airsprings (DIY), Magnaflow mufflers with 3.5" tips
    Summers: Yokohama Avid W4S/RS6 Reps
    Fog DRL's, Toggable 628 Relay, Tip Override Recode, Remote Window Recode, Clear Corners (DIY)
    Timing Belt DIY (at 60K miles), Tiptronic Drain & Refill Service DIY (at 62K miles)
    GET OEM PARTS HERE: http://www.europaparts.com/
    Apr 18 2007
    ny
    Re: Engine Wash
    I just use a wet towel and go at it, I really don't feel comfortable opening a hose up on my engine.
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    Re: Engine Wash
    i sprayed mine down quick at the carwash with that degreaser and water... worked really good (kept the car on) ~ didn't have any problems
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
