Results 1 to 7 of 7
    Established Member Two Rings SouRce4's Avatar
    Dec 02 2006
    New turbo install... Coolant question
    I installed my new k03s in my 99.5 1.8t. i just got back from college and still everytime i start the car it beeps and flashes the coolant light. the tank is right at MAX and is not low at all. Where exactly is the sensor located that it is reading a coolant problem... could it be that the coolant isnt flowing thru the turbo correctly? any ideas?
    '99.5 A4 1.8t FrontTrack 5spd
    ST Chipped K03s :: Custom Catback Exhaust :: Bailey DV :: Custom Intake
    Koni Coilovers :: Strut Bar :: 8000k HID's
    Custom Interior :: Custom Dash and Gauges :: 30% Tints
    Blacked Out 360°
    DÜB Wehrmacht / / / Many Audi's and VDubs
    Nov 19 2005
    WA
    Re: New turbo install... Coolant question
    The sensor is on the back of the Cylinder head right next to the firewall. It should either be blue or green in color.
    2017 Platinum Gray Metallic Golf Alltrack SEL
    Dec 02 2006
    i figured it was that sensor. i replaced it when the flange was leaking so i no it is still good. now my question is tho. if that is reading low coolant or coolant problem (watever the light means) where is the potential collant issue... the turbo or somewhere in the block. basically i just wanna make sure that my new turbo is getting the correct amount of coolant
    Blacked Out 360°
    Veteran Member Three Rings Rico750's Avatar
    May 19 2007
    B7 S4| 07' R1 | 08' R6 | 09 X6 |
    Tennessee
    make sure the coolant plug underneath the coolant reservoir is connected correctly.. unplug it and plug it back in..
    2004 S4 | 18" RS6 rep Rims | Valentine 1 | BOSE + Blaupunkt sound | K&N | H&R sport 1.2" lowering | KONI | 30% tint | FI down-pipes | FI catback 2.5" | JHM tune |
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    ^^^^^X2, it happened to me as well, when i checked it was unpluged.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Dec 02 2006
    still seems to come up flashing. should i unplug it and reset the batt or something? ps whats the diff btwn flashing and solid coolant light
    Blacked Out 360°
    May 19 2007
    Tennessee
    it flashes i believe if its unplugged.. so you made sure it's plugged in correctly underneath the reservoir. Trace that wire back and look for cuts... check the plug on the "green coolant sensor" close to the firewall (could also be black if never upgraded)
    might also be time to get the green sensor if you never upgraded.. shouldn't be expensive
