Results 1 to 6 of 6
    Registered Member Two Rings
    Jul 14 2007
    Milwaukee, WI
    Uneven Break pad Wear
    Ok so I replaced all 4 corners, pads and rotors in august of 2007. slotted rotors and a high quality pad. All from ECS tuning. Ive noticed I have uneven pad wear, specifically on the drivers side front and less noticeable on the passenger front pads. The out pad (haven't pulled a wheel to check the inners yet) is more worn towards the outside of the rotor. What could cause this and how do I go about fixing it? Do I need to replace the pads again?
    2003 a4 1.8t Q 5spd/apr stage 1+/carbonio intake/apr r1 DV/ APR TIP/ECS slotted front and rear rotors with Hawk HPS pads/ Amulet Red with grey lowers /oem audi ipod interface/cold weather/xenons/sport
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: Uneven Break pad Wear
    It's normal to get some uneven wear on brake pads. Sometimes I'll see pads that are almost gone on one side and 20% on the other.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Quote Originally Posted by dirtybrd View Post
    really? i was pretty certain that it isn't normal and is usually a caliper issue.
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    bleed the brake system with new fluid. make sure all sliding parts that need to be greased are greased.
    Mar 21 2006
    Lakeland, FL.
    You could have an issue, but if everything is lubed and moving, it's ok. I've been a auto tech for almost 15 yrs.
    I'm back bitches!
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    Quote Originally Posted by BARRY View Post
    Great Post and Idea... It is normal when I changed my rear pads it was uneven as hell .. I greased and re-torqued everything but it is bound to happen again... Doesnt happen on stoptech and those bigger brakes because of the evenly distributed brakes pistons.. Single pistons will definatley do that....
