When i went stage 3 almost a year ago, i went with the ecs stage 3 clutch kit which consisted of a kevlar disc and ecs's lwfw which i believe is a fidanza. it worked great for quite a while, but after 2-3 trips to the dragway, and some heavy street abuse the clutch is absolutely trashed now. i dont know if i didnt break it in carefully enough, or if it couldnt hold the power i was throwing at it.
So now i am looking for a replacement. I did some searching, and i think it has come down to these three:
1) Vast stage 3 ceramic hybrid - from what i understand it will work with the lwfw i have now, and it is all around pretty strong
2) CM FX400 - i am still confused on which fw i can/cant use with this. if i were to get this clutch, i understand that i need the stage 3/4 segmented one due to some fitment issues with the flywheel bolts?
3) SB OFE Series Stage 3/4, or SB FE Series Stage 5. I havent found any information on these two clutches on whether or not they can be used with the lwfw i have now.
as far as price, i think i have found that the CM is cheapest, followed by the vast, and the then the SB being the most expensive. with all this being said im not sure which one to get. if anything i want the strongest one and go overkill (SB stage 5) to make sure i dont have to replace another slipping clutch, but then again it is most expensive. excluding the SB stage 5, which of the three would you get?
