Results 1 to 15 of 15
    Senior Member Two Rings WhiteA4's Avatar
    Feb 29 2008
    South Texas
    2003 A4 -1.8 TIP- Low Speed Hessitation/Stutter
    Recently, I have noticed my car stuttering or hessitating
    in the 25-35 mile per hour zone, when slowly accelerating.
    If I step on the gas a little harder it wont do it..
    THe car feels like its stutters for a few seconds while
    goin through 25- 35 mile per hour and after 40 and beyond
    you wont feel it... It does this at random times.
    The car is completely stock..
    I replaced the coil packs with ECS tuning Hitachis Stage 1 and
    no change.. It is a bit smoother, but It has not change this..
    It does it more when it's hot out...
    What could this be?
    There a no codes, nor blinking cels .. I have vag'ed the car multiple times, and have replaced the spark plugs with denso iridiums.
    DO you think it might be a fuel problem?
    BAD MAF or fuel filter?
    Any ideas
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Re: 2003 A4 -1.8 TIP- Low Speed Hessitation/Stutter
    Any codes?
    Senior Member Two Rings tray1187's Avatar
    Feb 20 2007
    2012 Hot Chocolate Mini Cooper
    Tampa
    I've got the same problem. I think it may be my engine mounts. Dirty bird if ur reading this I'll need u to to replace those mounts after all. I checked them the other day and there was dried purple goop on the outside of both of them.
    Quote Originally Posted by WhiteA4 View Post
    What could this be?
    Any ideas
    Feb 29 2008
    South Texas
    No codes.....
    Any suggestions..
    Should I replace the MAF and Diverter Valve
    Feels like it skips or stutters for a min while crusing at low speeds
    Feb 29 2008
    South Texas
    Anybody else!
    Feb 29 2008
    South Texas
    Anybody else!
    Veteran Member Three Rings A4p's Avatar
    Mar 06 2006
    Audi 1.8TQM6 S-line USP 2004
    Sweden
    I think you need a snub mount apr and a new clutch. i would also recommend a new exhaust and chip it.
    USP CLUB MEMBER 861
    Rev0 stage I file - 300+ bosch injector - OFE SS - APR Snub mount - Nitrogen - RS4 Swaybar - K&N air filter - **-
    Feb 29 2008
    South Texas
    Added a bottle of fuel injector cleaner... Techcron... and it seems a little
    better than before..... Hessitation is still there.. A little less noticiable...
    Fuel Filter Clogged? BAD MAF? Replace diverter valve or N75 Valve..
    Weak fuel pump?
    Feb 29 2008
    South Texas
    No suggestions?
    Feb 29 2008
    South Texas
    Replaced the fuel filter ... No change
    Registered Member Two Rings
    Feb 07 2006
    ouellette
    Don't be bummed about the money you've spent replacing things already, it's all stuff they would die on an 03 soon anyways.
    if it were me, I'd try changing the spark plugs next. They're pretty cheap, and you've already ruled out a lot of the obvious stuff already. After that I would suggest vag-com, and watch boost and air/fuel.
    what does the engine sound like when it does this? does it sound like it's misfiring?
    Established Member Two Rings tarzjdm's Avatar
    Jul 15 2007
    B6 1.8t FWd
    san dayGo
    that sucks man! I have the same problem too... I changed both my motor mounts, DV, SNub mount, spark plugs, and coil packs but still no luck. The tech from audi took my car for a test drive once and he said it could be the clutch packs in the CVT trans..
    Feb 29 2008
    South Texas
    Raplaced the spark plugs with some NGK BKR6E's and nothing..
    If at all the problem became a little more noticiable now with the cooper plugs
    than with the Denso Iridiums I had there for 10k ..
    Things.. I've done to the car.
    New Coil Packs- ECS Stage I - ( AKA Hitachi E's)
    New OEM Fuel Filter-- No Change
    New NGK Spark Plugs- BKR6E's - Problem abit more noticiable.
    What's next ...
    Do you all think It may the diverter valve.. Or a BAD N75..
    I vagued the car at wot .... THe maf a idle reads 2.46- 2.53 g/s
    at wot it goes up to 142 g/s ... Is this right.
    Feb 29 2008
    South Texas
    Cleaned MAF ... Same story.... Could the maf be shot..
    May 28 2008
    2002 Audi A4 1.8T
    St. Louis
    My car is at the dealer for the same thing right now. I changed everything you did as well as all my spark plugs. They can't figure it out but they are calling Audi on Monday to see what they say. There is a TSB for exactly the opposite thing, stuttering during deceleration so they are going to see if it might be related. But they told me to be prepared for the news to come back and say the CVT is busted.
