    Apr 14 2008
    a4 avant
    marlboro
    video of the avant
    heres a video of my car running 15lbs and not going over half throttle due to misfire issues
    against a chiped m3 with around 300-340 chp (i believe)
    http://youtube.com/watch?v=Yt78ZxHMiZw
    -vrt-
    Veteran Member Four Rings belinko's Avatar
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    Re: video of the avant
    Not to knock your socks, but why post a vid of a vehicle that's not even running properly?
    If we assume that your car is running 100% then you'd take the chipped M3. Props on a nice run with a fast car, but I'd rather see your car punish the M. Perhaps a little patience would go a long way. $.02
    1.8L, JE pistions, IE rods, APR stg3+, GT28 Turbo, Setrab, ER comp. FMIC, APR HFC, Milltek Cat-back, APR 91, 93, 100 - CM FX 300, CM 240 LWFL, JHM 4:1, AMS SS, RS4 Motor Mounts - 355mm Alcon 4 pot, 300mm Alcon S4 - Stasis/Ohlins MS, Hotchkis Front and Rear, Stern adj. CA Front, 034 adj. CA Rear - 18x8.5" Work CR Kai wheels, NT-01 & Dunlop Z1 star spec - RS4 Front bumper and grill, Tow Strap, RS4 E-codes - SPA Technique Dual Digital gauges Oil & Water temp, Oil & Boost pressure, RS4 Door Handles
    Apr 14 2008
    a4 avant
    marlboro
    my friend posted it for me so i figured id give a little preview to what it will be after this week
    -vrt-
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    Let's see it when it's ready. I don't like hype, I want to see results.
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    not bad at all, you better post the vid after your car is completely running 100%.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
