so after the car went stg3 it was fine for awhile then i developed a coolant leak. i knew it couldnt be my aux pump cause i replaced it at that time. it was leaving a puddle sometimes right in the middle where you would think its the aux pump. i started thinking it might be a head gasket cause it was building pressure and i was getting coolant residue right outside the coolant cap. i threw it on the lift and the pass turbo coolant line was leaking coolant and running down making its way over to the middle. i tightened it up but i knew that was not the issue of the pressure forcing it out the cap. i decided to buy a new coolant cap and check my old one. sure shit it was a bad cap. it was holding almost 20 psi and im pretty sure thats high. anyways no leaks anymore
