Results 1 to 7 of 7
    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2017 B9 A4 Quattro/DSG/Technik/S-Line... 2004 B6 A4 1.8T Quattro race car
    Montreal, Canada.
    CAR UPDATE: We're almost there and I can finally see the light at the end of...
    The tunnel...
    My electrical nightmare is coming to an end! BTW, I should be getting some very nice goodies by the end of next week if everything works out. It will make all those “dash critics” shut up.
    We removed so many circuits and systems from the car that there is only a dozen of fuses required at this point to protect what circuits are left in the car and four of them are for the ECU by itself! So it is bye bye to the OEM fuse box!
    Finally here’s a picture of what left to hook up to complete the job. As you can see there is a lot less wires and I mean a lot less then when we started! LOL. Some of these wires will not be used in the end and removed. All I can say is this is the most time consuming and labour intensive both in time and money project on this car so far. It’s actually costing me more than the roll cage.
    Veteran Member Four Rings jrau13's Avatar
    Mar 12 2006
    02 Mercedes ML, 04 Avant 1.8t
    Costa Mesa
    Re: CAR UPDATE: We're almost there and I can finally see the light at the end of...
    I mean whenever I see your post all I can come up with is WOW!
    I'll keep my money,
    My Guns, My Freedom,
    & you can keep the CHANGE
    Sep 02 2005
    Montreal
    What is the estimated power to weight ratio going to be when it's all said and done? Looks like there is a lot of weight coming off from the front, which is good, I guess the weight distribution is going to be much better, right?
    Jun 17 2004
    Montreal, Canada.
    Oh BTW, the car was started several times to test things out and everything seems to work properly... So far! :-)
    Jun 17 2004
    Montreal, Canada.
    Power to weight... Unknown at this time. Need to get it weighed once it is done.
    Actually a lot of weight came off the back end so far and that no good for the balance. However there is still a lot of weight that needs to be pulled out and most of it will come from the front.
    Dec 18 2006
    03 A4 1.8t | 04 IB M3 SMG
    Hanover, NH
    Are you goign to like upholster the thing once you're done?
    Now: RNS-E | Debadged | GIAC 1+
    Soon: Caractere front and sides | S4 Rear | S4 Doorblades | Bi-Xenon E-Codes
    Future: GTRS BT Kit | Tip Tranny upgrade for BT Kit
    Jun 17 2004
    Montreal, Canada.
    Quote Originally Posted by 47Ronin View Post
    Upholster a track car? Don't think so.
