    Apr 18 2008
    Jacksonville, FL
    Unhappy 1k mile TIP making odd noises!
    got a hair over 1k miles on my car, and i've noticed a sound coming from what i assume is the transmission. on the first shift from first to second of any drive, i'll hear either a muffled gear-griding sound or some type of thunk. only happens the first time, and it does seem to delay the shift. i'm smart with my car - i let it warm up before i go past about 2k rpm. after that first one, it's fine...shifts like butter. yesterday, i heard a slightly different clunk from the front left corner, almost from the front left suspension assembly. i was on flat pavement. anyone ever experience anything like this? haven't taken it in to the stealership yet, i was planning on waiting till the 5k service and have them drain the tranny fluid (if they don't do it anyway) to check for shavings.
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
    Jan 01 2008
    Long Island NY
    Re: 1k mile TIP making odd noises!
    The tip is a weird it could be normal it, but just take it to the dealer and have them check it out.
    Forum Moderator Four Rings blacka4's Avatar
    Dodge RAM 1500
    Pittsburgh Area
    they are not going to drain the fluid even if you ask them to do so.
    -Rob - Moderator - PM Me!
    RIP:1999.5 Audi A4 1.8TQ Tip Brillant Black
    2009 Dodge RAM 1500 Crew Cab Sport - AZ Plate Frame - Bone Stock otherwise
    2014 Jeep Grand Cherokee Summit
    Active Member Two Rings Tunerstop's Avatar
    Jan 22 2008
    Socal, CA
    I don't think thats the transmission. That sound is coming from your brakes. My car made that sound when i had less than 500 miles on my car. I already took my car in for that, the sound went away, and now its back. I think it was from the caliper seals..it makes a humming sound correct?
    08 A4 S-Line 2.0T - TSP BOV, H&R Springs, 20% Tint, 6000k HIDS, 3000k Fogs, 19" BBS LM's
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    yea you don't want to drain the tranny fluid that early. if you can keep the car there overnight and show it to them in the morning that's the best method.
