Results 1 to 6 of 6
    Senior Member Three Rings 102487thedude's Avatar
    Apr 06 2007
    BMW M3, X5 50, A4 BT
    Cresskill new jersey
    removal of combination valve
    I did the search and found some information but i want to know what else i can remove after i have removed the combination valve/secondary air valve. I will delete that code so that it will not throw a check engine or a cel light.
    2.0 stroker, built aeb head, T3/TO4E t-61 BB F162 .63AR turbonetics turbo, front mount, open down pipe. Port and polished intake manifold. 800cc injectors.
    and a our New cayane GTS in red.
    visit,
    http://quicktimeperformance.com/
    http://www.theshopct.com/
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: removal of combination valve
    Everything attached to it. I have none of that stuff.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Apr 06 2007
    Does that include the black pump on the bottom of the car. and what do i do with the black line that comes out of the top half of the combination valve which goes to the lines under the intake manifold which are part of the crank case breather system.
    visit,
    Senior Member Two Rings a4_1.8t_01's Avatar
    Feb 24 2008
    A4 1.8TQM 01
    I might do this also. Did you put a filter on the end of the valve cover? Or do you need a catch can there? Thanks
    Unitronic tuned. love it.
    Need any services done in NYC area please PM me. I will diagnose and fix your car. Also do clutch replacements, Timing-belt services, Turbo upgrade/installation, Fluid changes, boost leaks and pretty much anything.
    Feb 24 2008
    A4 1.8TQM 01
    The black pump goes away and the egr can be blocked off but I dont know what you do with the valve cover hose that goes into it.
    Apr 06 2007
    i have a catch can on the hose that comes of the valve cover.
    visit,
