Results 1 to 9 of 9
    Senior Member Two Rings cecaa's Avatar
    Feb 13 2008
    2007 A4 2.oT MT S-line Ti
    Vancouver BC
    Thumbs down Audio upgrade problem with OEM heal unit, subwoofer distortion
    I recently got an ALPINE PDX-5 amp, 4ch+1sub ch (300w sub, 600w total rms). Mounted a 10' Alpine Type R in a sealed box. Those are connected to the factory head unit. the oem sub has been taked off.
    The problem is , when subwoofer is hitting , I can hear very significant distortion from the subwoofer or something in the box ( at least feels like this ). The installer told me with factory head unit, the signal is not good, even tho I bought and installed the output signal converter from them.
    They did very bad job on mounting and wiring which I will get back to them later, but with the $1000+ system, the sound shouldn't really be like this.
    BTW, I didn't even turn it loud!
    AFter the installation, I also felt the 4 door speakers now sounds quieter and there is no low frequency sound coming out from them at all.
    Now I feel like
    Sponsored by VMR
    2007 Imola Yellow A4 2.0T S-Line Ti 6sp.
    235/35/R19 RS4 Replica. Bilstein Shocks. GIAC 93X. Rear Windows Tint. Lamin-X Smoked Tail light/Fog light. Metallic Black Rear Rings. Debadged.
    2004 Imola Yellow TT 1.8T Tip. Gone but not forgotten.
    ________________________________________
    Everyday is a gift, that's why we call it present.
    Veteran Member Three Rings Kschroers1's Avatar
    Jan 12 2008
    17' Jeep Grand Cherokee Limited 1942 Edition, 12' A4 Premium S-Line 6spd Quattro
    Roanoke, VA
    Re: Audio upgrade problem with OEM heal unit, subwoofer distortion
    Their is something they did wrong there. They should've never touched the OEM head unit. All that is required from the front of the vehicle to the rear is the Power cable to supply voltage to the amp. Everything else can be done by wire tapping into the OEM subwoofer thats connected to the OEM amplifier on the right quater panel area of the vehicle. Of course unplug the OEM sub. Then just test for a lead that supplies constant voltage to tap in your remote(blue) wire. I paid $250 for my 10" Alpine and a simple box and it hits hell'a hard with absolutly no distortion or anything screwy with my OEM speakers.
    Veteran Member Three Rings gyroscope's Avatar
    Mar 19 2007
    06 A4 S-Line Quattro, 98 K1200RS, 21 GTI SE DSG
    Queens, NY/Poconos, PA
    If the sub is distorting and your factory components are missing their low end, there is either a voltage drop somewhere causing the amp to run at half power, or you may need to bridge the amp to use it's full potential. The first thing I would do is is to check the gain and the crossover frequency knobs while the system is running/playing. Tweak those two parameters first and see if you get any sort of change. chances are the installers screwed something up, possibly by not reinstalling the paasive reisistors or crossover components.
    Registered Member Two Rings Ski DraGoN's Avatar
    Sep 24 2007
    fl
    Sounds like they ripped you off and now they want to rip you off some more. Go somewhere else.
    Veteran Member Four Rings LimiTed's Avatar
    Oct 13 2006
    Bay Area
    Quote Originally Posted by Kschroers1 View Post
    yup. the only thing that ran from the front is the power. my signal and remote hooked up to the harness that plugs into the stock amplifier. that way you're disconnecting the stock amp and sub as well. i have a 12" type-r that hits hard and clean. your head unit should have never been touched. if you search there's a thread that has the pinouts to the stock harness that you can tap into.
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    If you bought products from them and they installed it, and it sounds like crap... go straight back there and tell them to fix it. You paid for the install which should be 100% correct, and something isn't right. Just say, "hey you guys installed a sub I bought from you, but it doesn't sound right at all. Could you look at it and see what's wrong?"
    Don't pay anything extra. You already paid for the install that should be right.
    Ignorance is bliss.
    Senior Member Three Rings BLACKa4QUAT's Avatar
    Mar 26 2008
    union city, ca/fort worth, tx
    i never had any distortion using a hi-low converter with my factory headunit in my old b6, as it was said before, they should have tapped the lines in the amp in the trunk, if i'm not mistaken there are also line level inputs going into the factory amp. its been a long while, and i had the bently manual to check it. now i just have an aftermarket headunit
    2006 A4 2.0Tqm, S-line, tech, FH-P8000BT, 10" sub, 800 watt,
    VAG-COM mods (remote windows, no chime), revo stg 1 tweaked
    AWE pedals, HRS4 DTMs/Eagle GT, VMR TP
    193.7 awhp/232 ft/lb/91 oct pre-TP
    16MAR09DSWHTAW
    Sep 24 2007
    fl
    Quote Originally Posted by Phrost View Post
    bump
    Veteran Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    Quote Originally Posted by LimiTed View Post
    So you take the signal before it enters the amp? Than you don't need a LOC or anything, right.......
    Can you please tell me what pins you have to tap? Non-bose.
    Regards
    E
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
