Results 1 to 9 of 9
    Veteran Member Three Rings mwbunns4's Avatar
    Feb 20 2008
    2011 Audi S4 6MT, Audi A3 TDI
    Savannah, GA
    Rear Deck Speaker problem.
    OK, so. i blew one of my rear deck speakers, and i am not sure what to replace it with. I dont want to get something that will sound worse than the factory bose speakers. Does anyone have any advice as to what size and what brand of speaker would be good? thanks for the help.
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Rear Deck Speaker problem.
    It's not blown most likely..the dust cap is loose and rattling around...Remove rear deck, epoxy dust cap back on.
    Senior Member Two Rings nvrfollow's Avatar
    Apr 19 2007
    Silver S4 - Laser S4
    Montana
    I have the same problem... If they are blown its better to not even bother with the deck speakers and put in a sub. The deck speakers aren't able to push that much air therefore somewhat of a waste of money when you could have a 10" subwoofer in the trunk for about the same price.
    Veteran Member Four Rings lrg8683's Avatar
    Nov 02 2005
    S4
    VA
    i went to circuit city and bought some 100 dollar polk audio speakers, they work just fine.
    http://www.circuitcity.com/ssm/Polk-...oductDetail.do
    -Luis
    Veteran Member Three Rings ChumbaWumba's Avatar
    Jun 06 2007
    i went to wal-mart n just bought some $50 sony xplods....it gets the job done =/
    Jan 29 2007
    08 S4 00 S4
    MD
    And the Bose amp uses 2 ohm speakers I believe if you have to go aftermarket. I'm willing to bet it's the dust cap coming loose...
    http://forums.audiworld.com/s4/msgs/1760180.phtml
    Nov 02 2005
    S4
    VA
    Quote Originally Posted by mholme View Post
    you can use 4 ohm speakers just fine.. what you can't do is use 1 ohm speakers.
    -Luis
    Feb 20 2008
    Savannah, GA
    thanks for the tech art. im gonna try it out. hopefully fixes the problem.
    Veteran Member Three Rings mmxruffryder15's Avatar
    Mar 28 2008
    new york
    u just cant put in any speaker if u want the same bass.. the rear deck speakers r 6 1/2 subs so if u replace them with regular speakers its gunna sound like shit...trust me thats wat i did but i sold them nd got 6 1/2 subs for them....ur best bet is to a component speaker kit which gives the 2 subs 2 door speakers nd 1 or 2 tweeters to start off then get subs for ur trunk
