Results 1 to 12 of 12
    Established Member Two Rings audi4u2nv's Avatar
    Apr 15 2007
    2002 a4
    bayside, new york
    Wtf!?!?!?! Helppppppppppppppppp!!!!!!!!!!!!!!!!!!!!!!!!!!!
    wow so my car is driving me nuts, i cant seem to finish fixing it..i have a 2002 audi a4 3.0 quattro, every month i have a new problem..i fix one thing another one starts...my CEL came on and the guy pulled the codes and it said "incorrect emission purge flow" or someshit like that..i forget the exact code number but its driving me nuts..WHAT CAN I DO!?! HELP ? what should i do?!
    outt1e
    2002 audi a4 3.0 Quattro
    magnaflows | 15% tints | tein supersport | k&n air filter | debaged | HID's in fog's | trunk lip |
    Dec 06 2007
    Re: Wtf!?!?!?! Helppppppppppppppppp!!!!!!!!!!!!!!!!!!!!!!!!!!!
    purge valve??
    -Kirk
    BetaAlphaTau Member #58
    Apr 15 2007
    2002 a4
    bayside, new york
    yeah purge valve
    outt1e
    Veteran Member Three Rings quattrotman's Avatar
    Sep 26 2006
    Gas cap?? It's a pretty common reason for a CEL on our cars. If so, take it off and screw it on again a few clicks. The CEL will go away after a few days if it doesn't sense the problem again. Even if it's not that and the car drives fine, ignore it for a few days to see if it goes away. Many times a CEL just comes up because one parameter was exceeded for one reason or another but nothing major.
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    fix the leaking hoses and check valves they are old by now. then check your purge valve if you don't find anything more obvious.
    if you don't do the PM to fix all the krusty plastic under the hood you will see this over and over and over. trust me its about 2x as bad with a turbo under the hood.
    purge valves not sure the 3.0 uses the same; are easy to test you can take it off blow through it both ways, if air passes = shot. Then take a 9VDC power supply and wire it to the two leads and blow through it; if it blows fine probably good. this is a nasty problem since any check valve or busted hose can mask itself with this code including some more expensive parts :)
    p.s. you should have replaced the gas cap by now on an 02' mine was pretty shot when i did mine earlyer this year
    02 1.8tqs - apr 1+ - SS forge - Hartmann B5 RS4 18" ET35 - Delsa (ebay) spoiler lip - debadged, B7 A4 320mmx30 front brakes - 335i Montego Blue/black; Sport;Prem; iDrive; Step and Heated Seats.
    Sep 02 2005
    Montreal
    Dude, your topic naming skills suck.
    Apr 15 2007
    2002 a4
    bayside, new york
    you serious, i actually have to change my gas cap, whats the problem with the one i bought the car with lol
    outt1e
    Veteran Member Three Rings AudiBama's Avatar
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    Quote Originally Posted by audi4u2nv View Post
    i think he means take it off and put it back on...and make sure its clicked on a few times...
    2003 A4 1.8T
    APR K04, APR Snub Mount, Forge 008 DV, Custom Magnaflow Exhaust, 034 Motorsport Catless Downpipe, K&N, VHT, Hitachi "e" Style Coilpacks, 6000k HIDs, CC Mod, Neuspeed Race Springs, Bilstein, Southbend Stage 2 Endurance Clutch, Lightweight Flywheel, Valentine 1, Driver Mod.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    It sounds like the purge valve is stuck open.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Nov 06 2006
    335is
    atlanta
    yah the check valve before my purge valve you could see the thermoset plastic crumbled away lodging itself in the purge valve; took it off blew through it , tried everything to backflush it - bought a new one and new check valve and boom done.
    i have a 1.8T so if you have something else the layout might be different. takes literally a minute to pop the purge valve off and blow or suck whatever you prefer :)
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    sounds like you hate your 3.0 enough.
    sell the car and get a 2004 or 2005 1.8T Q 6spd.
    I wouldnt keep on fixing shit if the car keep poping all this crap in your case.
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Registered Member Two Rings
    Feb 07 2006
    ouellette
    I agree, sell it. Some people don't mind having older cars that need repairs, other people hate it.
