Originally Posted by
InTTruder
You guys need to grow up some, it seems.
Changing front Camber has a positive effect on turn in, and negative effect on wear and track. Unless you race daily, or for a living, avoid high negative front camber. Have you ever seen
THIS CHART
Agreed, I stepped off my high horse.
Negative Camber isn't a bad thing. Most production cars have negative camber off the line. Too much is not a good thing. -1.5 degrees on a street car isn't a big deal. The first time I aligned my car it had -1.4 and -1.2 in the rear. I put it back into spec, but there wasn't any noticeable tire wear
onemoremile
Anything under 2 degrees of camber won't change tire wear much. Tire longevity, tracking, and even turn in are more effected by toe than anything else. If you've got negative camber and bad toe settings the insides will wear quickly and make it look like camber is at fault. If you had 0 camber but bad toe the whole tire would wear funny (feathering the tread towards the inside or outside) and quickly, tracking would be terrible, and gas mileage would suffer along with acceleration and braking. Negative camber hurts braking more than anything else.
Excellent post by the way. I've used that chart often for everything from helping forum members and
setting my car up for the track to tweaking cars in video games.
Agreed, The first thing covered in Steering and Suspension is that Toe is the primary tire wear angle. As far as recommendations for toe on a tracked car, AutoX car, etc, I'm not a good source for this info as I have not tweaked my car for such events. I set it at streetable specs that will be predictable when I play with it.
Some negative camber is favorable on a out of the box car. It helps prevent the car from wandering or following wear patterns in the road.
Positive caster does help reduce turning effort, but too much makes a horrible ride and instability at higher speeds.
Many European luxury sedans have a lot of caster for this very reason because it provides a more stable feel at highway speeds. The downside is that it increases steering effort and steering feedback to the driver.
I don't remember what the Caster Spec is for our cars. I'm 99.9% sure from the factory it's Negative 2-3 degrees. I just aligned my car, and yes my caster is a lil screwy, but it's supposed to be negative. At least that's what Hunter's Specs were for my car w/ 1BE suspension.
I appologize for my previous comment, I wrote out exactly what I was thinking, not a editted logical thought process. I didn't see how the caster could be adjusted that far positive.
