Results 1 to 12 of 12
    Registered Member Two Rings
    Sep 10 2007
    2004 Dolphin Grey s4
    orange county ca
    Question Check Engine Light
    started the car up like normal today everything seemed fine....drove across the street to target shopped for an hour....came back out started the car up and i noticed a slight shaking/rumbling from the engine didnt think anything of it then sure enough i see my yellow check engine light......the digital readout says OK in green so im wondering what can be wrong....i plan on trading it in soon so i would like to get that cel outta there....any input at all would be greatly appreciated....btw i have an 04 s4 52,000 miles im in so cal so the climate is definetly moderate.
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    Re: Check Engine Light
    Coil pack going out.
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Sep 10 2007
    orange county ca
    thats not good......how much will that hurt the pocket book.????????????...my warranty ran out a few thousand miles ago :-(
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    Coil packs aren't that expensive. ECS has the Audi OEM and the Bremi part for $29.95 each. Now the trick is to find which one is bad. The car needs to be VAG'd.
    Sep 10 2007
    orange county ca
    Anyone in oc up for letting use their VAG ??? And once i find out what pack it is how hard would the install be ??
    Sep 10 2007
    orange county ca
    now whenever i accelerate i experience a sort of slipping or mis-firing of some sort...any input????
    Sep 10 2007
    orange county ca
    my next question is should i be alright driving for another day unti monday when i can bring it in
    Senior Member Two Rings jester7677's Avatar
    Mar 24 2007
    NH
    Don't keep driving it. A coil pack is one of those red things on the top of the engine.
    Part should be $30.
    1/2 hour plus for labor depending on which one it is.
    Very simple to DIY.
    Sep 10 2007
    orange county ca
    how do i change out cp's ????? what tools will i need ? Plus i need a vag reading before i know what cp it is
    Sep 10 2007
    orange county ca
    and what will happen if i do drive until monday morning ??
    Jan 14 2008
    B8.5 S4 - 6MT Sepang/Panda
    Calgary
    You need a flat head screw driver, if any tools at all.
    My advice, make sure the engine is cool so you don't burn the crap out of your hands like I did (those suckers stay hot for a long time!).
    Disconnect the harness from your coil pack, pull it out of the engine, insert new one, done.
    Sep 10 2007
    orange county ca
    so now i just have to find out which side is mis firing correct?
