Results 1 to 9 of 9
    Active Member Two Rings shortyepic's Avatar
    May 09 2008
    Las Vegas, NV
    Lowering Question (please help)
    i have a b7 titanium package with stock 18's and sport suspension. how does this setup look? (i dont want to get coilovers)
    H&R RACE Springs
    H&R Trak+ 10mm front 12mm rear spacers
    Senior Member Three Rings tdavit's Avatar
    Aug 27 2005
    CT, FL
    Re: Lowering Question (please help)
    but you are going to get springs. not such a good idea...
    May 09 2008
    Las Vegas, NV
    do u guys think it will rub with this setup?
    Active Member Two Rings Tunerstop's Avatar
    Jan 22 2008
    Socal, CA
    No it will not rub, H&R only makes sport springs. Race Springs are not available for B6/B7's
    08 A4 S-Line 2.0T - TSP BOV, H&R Springs, 20% Tint, 6000k HIDS, 3000k Fogs, 19" BBS LM's
    May 09 2008
    Las Vegas, NV
    bump please??
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    If 10mm and 12mm will push your oem wheels out to make them about flush, I don't see any problems. You may have to remove the torx screw at the top edge of the front fender liners, but H&R Sport springs just don't drop that low where it becomes a problem I have heard.
    Ignorance is bliss.
    May 09 2008
    Las Vegas, NV
    should i get race or sport springs from h & r?
    Jan 22 2008
    Socal, CA
    h&r Race Is Not Available
    Jan 24 2007
    Wisconsin
    ^ Yup. I believe H&R Sport springs drop the lowest (1.7" front, 1.6" rear) for just springs. If you want to go lower, you'll have to buy coilovers.
    Ignorance is bliss.
