Results 1 to 21 of 21
    Veteran Member Four Rings A4 KiDD 810's Avatar
    Aug 25 2007
    B6 S4
    Westchester, New York
    Hissing during boost
    Hey, I just got flashed last thursday, but something happened friday, and I just got the car back this thursday. Anyway, Today on the way up to a local meet, I noticed a pretty noticable hissing if i'm flooring it or mostly flooring it, and i'm past 3k rpm. My friend said its just the turbo spooling alot louder now since the flash, but I have my worries that maybe a hose came loose of the DV or there is possibly a boost leak somewhere causing that sound. Is it normal? I dont really remember hearing that kind of hissing on other people's cars that were chipped. I dont have a boost gauge yet so yea I know thats the 1st part of the problem, so Idk what I'm boosting and if I'm at full power or not. Thanks for the comments.
    -Nick
    -2004 Brilliant Red S4 6Spd - Thermal R&D Catback, FK Coils, Piggie pipes, JHM Tune
    -2002 Brilliant Black 1.8T 5Spd - (traded in) Gone but never forgotten
    Veteran Member Three Rings Carlitos's Avatar
    Sep 17 2006
    B6 A4 1.8T
    San Juan, PR
    Re: Hissing during boost
    boost leak test...
    you are suppose to hear the k03, but not THAT loud.
    FlexTuning
    Amulet 1.8TM
    BAT#46
    Veteran Member Four Rings EYE4SPEED's Avatar
    Jan 14 2008
    Macan Turbo, Cayenne Diesel, Audi Jr Quattro
    West Coast of Michigan
    X2 after my GIAC flash and APR exhaust install... At first, thought it was a loose connection from the cat to the dp, but sound is only on hard throttle. Do have a Forge DV going in soon...
    FS: Audi TT 225Q Roadster
    Jan 10 2007
    VA
    Getting chipped will make the turbo spool more audible, but its a high pitched noise like a wistle. If it just sounds like 'hissing' you probably have a boost leak. Check all hoses and connections.
    Aug 25 2007
    B6 S4
    I mean maybe it has something to do with the DV cuz when I had the stock DV in before I lost the car for a week, I drove about 60-70 miles on it and heard no hissing at all in boost, now I have a Bailey Motorsports on and its just hissing after 3k. Idk i dont feel like dealing with this shit right now its been such a long day and a long week waiting to get my car back from repairs i cant even think of sending it back in.
    -Nick
    Veteran Member Four Rings quat's Avatar
    Apr 06 2007
    A4 Quattro 1.8T, H-D VRSCA
    Pittsburgh
    Have you noticed a power loss?
    Aug 25 2007
    B6 S4
    There could be a small power loss, actually now that I think of it I'm gonna go with yes, since I noticed a little bit that my 2nd and 3rd gear pulls were a little weak. So how much is this one gonna cost me ?
    -Nick
    Apr 06 2007
    Pittsburgh
    my bet is a boost leak. run a test. find out where you are leaking and then someone can tell you how much
    Oct 22 2005
    Reppin the Mitten.
    Get a boost gauge so you can regulate this regularly. But like everyone says, check for a boost leak.
    Feb 17 2006
    boost leak - also good to change that DV valve
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    I got flashed recently too and noticed an increase in sound at 3K+ too. I'm pretty sure it's the turbo spooling. It's much more audible than stock, but I wouldn't exactly describe it as hissing. More of a whistle, but it does have a very slight hissing noise where it didn't before. Who knows, we both might have boost leaks, but I think it might be normal. Keep me updated so I know if I should check or not.
    -Nick
    2008 B7 A4 Avant 2.0T 6spd
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    Yup Same thing with my car, it got a little bit louder and when i hit the gas around 3k and it spools you can hear it..I like sitn next to jersey walls and doin it..haha..Sounds cool
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    Get a Boost Gauge Son.... It lets you know the moment something aint right... It will be your friend....
    May 21 2007
    Florida
    i run a bailey motorsports DV too and i get a hiss too. had it on my old 2002 a4 and on my current 2004. im not too worried about it. sounds just like a rush of air right? that seems to get faster as you accelerate? deff not the turbo.
    2018 Navarro Blue Q5
    Aug 25 2007
    B6 S4
    Quote Originally Posted by doublezero30 View Post
    Yup thats exactly it.
    -Nick
    Veteran Member Four Rings jrau13's Avatar
    Mar 12 2006
    02 Mercedes ML, 04 Avant 1.8t
    Costa Mesa
    Kidd-check this thread http://www.audizine.com/forum/showth...%27s+this+hose
    I had a similar issue recently and it was this piece. It would only happen under boost but other than that the car drove fine. Do a boost leak test and you will hear air escaping from around this area if this is the problem. Its a tough one because it would only happen under boost so other than that the hoses and the actual pump looked perfectly fine. When boosting it would separate.
    I'll keep my money,
    My Guns, My Freedom,
    & you can keep the CHANGE
    May 24 2007
    Southern California
    after i put my atp manifold on, i had a super loud hiss, almost screeching sound. but the mani to turbo bolts werent torqued enough. just trying to throw things out there.
    Kyle
    2.0L Revo GTRS Eliminator
    Senior Member Three Rings 102487thedude's Avatar
    Apr 06 2007
    BMW M3, X5 50, A4 BT
    Cresskill new jersey
    Do a Boost leak check. Check around the derverter valve and all the boost piping connections. also check intercoolers make sure nothing craked one. Also check the oneway check valve on the top of the motor behind the intake manifold it is common for the valve to crack when running more boost. Also if you have changed injectors make sure you seated them good and did not pinch the o ring if so boosted air can escape creating the noise as well. Check this link out.
    http://www.audizine.com/forum/showth...=Secondary+air
    2.0 stroker, built aeb head, T3/TO4E t-61 BB F162 .63AR turbonetics turbo, front mount, open down pipe. Port and polished intake manifold. 800cc injectors.
    and a our New cayane GTS in red.
    visit,
    http://quicktimeperformance.com/
    http://www.theshopct.com/
    Mar 12 2006
    Costa Mesa
    Good info but that's the same link that I posted. Just sayin'
    I'll keep my money,
    Apr 06 2007
    Quote Originally Posted by jrau13 View Post
    Damit didnt see that. hahaha
    visit,
    Aug 25 2007
    B6 S4
    BUMP ! Now I know 100% it's a boost leak. When I got home today I actually made sure that my APR 1+ was in chipped mode. Car just isnt pulling the same now. Gotta get this crap looked at soon. For some reason I just get this feeling its one of the hoses on the DV that came loose from so much boost or something. Whatever. The crap never ends.
    -Nick
