hey guys,
I just bought an 02 A4 1.8T quattro 5spd w/70K on it.... and the very next day I get it home the check engine light comes on... So I take it to autozone and they tell me the code is P0171 and give me these possibilities:
1. If bank one and 2 codes set together then suspect fuel pressure or MAF
2. O2 sensor defective
3. Ignition misfire
4. Fuel injector problem
So I only had one code which made me skip 1, and assume it was the O2 sensor and got the dealer to give $150 to buy a new O2 sensor. However now that I'm not even sure thats the problem.
My next problem, which is the more URGENT one at the moment is it's overheating badly. I drove it for a week and everything was perfectly fine but last night just as I was getting home the dash beeped saying "coolant" and I look at the temp sensor and it is all the way on H. So this morning I go out there to see if it really is low on coolant and see that it's very full of orange coolant. So I start the car again and let it idle in the driveway for like 20 mins and it gets up to temp but does not go over(the fans did come on though) so I thought maybe it would be ok and start to drive it but I only get a couple blocks away and it starts overheating bad again, so I immediately go home and open the hood, and crack the coolant resovoir and it spews a ton of coolant out the bottom of it. So do I have a bad thermostat? Is the water pump seized?
The dealership is like 3 hours away, and they are a pain in the ass to deal with, so I want to avoid that but if I have to I will take the car back.
