Page 1 of 7 123 ... LastLast
Results 1 to 40 of 241
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    The Spacers Thread
    Alright time for a reference/ show-off thread. All you peeps who have spacers on, go ahead and post them.
    It would be nice if you could indicate the name/model of your wheels, offset, size of spacers, and most importantly pictures. Also post if you have had problems in the past without having spacers etc.
    i hope i don't see any more threads about spacers. :)
    here's a couple of threads for you people who are lazy to search
    stock 17's:
    http://www.audizine.com/forum/showth...hlight=spacers
    Veteran Member Four Rings LAS's Avatar
    Feb 12 2004
    HI.
    Re: The Spacers Thread
    great thread. now maybe I (and we) can stop repeating ourselves.
    here's some help to those 2 posts above:
    VVVhttp://www.audizine.com/forum/showth...hlight=spacersVVV
    Quote Originally Posted by Elohite View Post
    i had 12mm front and 15mm rear, its still not flush but was close to it
    anything less looks horrible as its tucked
    Quote Originally Posted by Bryson View Post
    Also..just got my 17.5mm spacers for the stock wheels, i figure i'd make the stance look better since im not getting rims for a while...and damn glad i got the 17's and not 15's, the 15's wouldnt of been enough to bring it flush with the fender-well.
    NOW THE SPACERS!
    nice and flush
    Nov 15 2007
    wow looks very nice and flush. from the rear it looks like a widebody
    Feb 12 2004
    HI.
    VVV http://www.audizine.com/forum/showth...hlight=spacers VVV
    Quote Originally Posted by Underpsi View Post
    Here you go. This is a A4 2.0T Sline with 12mm front and 15mm rear spacers with coilovers dropped to 25" front and rear; these spacers are now for sale in the classified section as I have new custom wheels on order which should arrive in a week or so.
    VVV http://www.audizine.com/forum/newrep...eply&p=2300236 VVV
    Quote Originally Posted by B7portgal View Post
    Pictures of 12mm H&R spacers...
    Before installation:
    After Installation:
    Sorry for all these pictures, I am hoping that this can help some of you decide whether or not to get these spacers.
    Feb 12 2004
    HI.
    Quote Originally Posted by B7 Angelo View Post
    MY stock 17x7.5 wheels (offset is 43?) i have 15mm spacers in the rear and 12mm spacers in the front. Tires are Stock Pirelli p6 (235/45/17) and car is sitting at 24.5 ground to fender on S4 PSS9's
    Hope they help!
    LUG BOLTS
    OEM:
    Type = Ball/Radius/Round seat
    Length = 28mm
    Diameter = 14mm
    Thread Pinch = 1.5mm
    Add the mm amount of spacer you will be installing to the length of the OEM lug bolts.
    ie: 10mm spacer = 38mm lug bolts (28 + 10)
    again...
    ie: 15mm spacer = 43mm lug bolts (28 + 15)
    If no exact size lug bolts are available, it would be safer to go the next size higher.
    Purchase online:
    http://www.purems.com/products/product.php/II=530
    http://www.parts4vws.com/catalog/pro...umber=14%2E5OE
    http://www.ecstuning.com/stage/edpd/...=Wheel%20Bolts
    AFTERMARKET:
    Most aftermarket wheels use Cone/Conical/Tapered seat. Check with manufacturer or supplier.
    Purchase online:
    http://www.purems.com/products/product.php/II=529
    http://www.parts4vws.com/catalog/pro...mber=14%2E5AFT
    Tirerack Tech...
    Proper Lug Nuts or Lug Bolts: http://www.tirerack.com/wheels/tech/...urrentpage=107
    Wheel Lug Torquing: http://www.tirerack.com/wheels/tech/...urrentpage=102
    - Hardware Bolt or Stud Size = 14 x 1.5 mm
    - Typical Torque Range in Ft/Lbs = 85 - 90
    - Minimum Number of Turns of Hardware Engagement = [b]7.5
    Related Thread:
    http://www.audizine.com/forum/showth...ighlight=bolts
    http://www.audizine.com/forum/showth...highlight=bolt
    Jan 06 2008
    Dacia Sandero
    Arizona
    Great thread! (add to FAQ)
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stërn . 034 . OEM+
    May 03 2008
    06' B7A4 20T Non-Sline
    Monterey, CA, 93940
    Quote Originally Posted by 4RingRook. View Post
    AGREE
    Veteran Member Three Rings tribe's Avatar
    Feb 15 2008
    lotsa tools
    Vienna, VA
    '12 Phantom Black S4 P+ S-Tronic- Navi - 3M Clear Bra - KW Springs - REVO Stage I - AWE S-Flo Intake - Hotchkis sways (still in the box)
    Nov 15 2007
    wow LAS. Thanks for all the info. did you type and look up everything?
    Nov 15 2007
    Veteran Member Three Rings darin1274's Avatar
    Dec 28 2007
    2016 VW Passat TSI
    Phx, AZ
    ^ thats for only 5mm....
    ...step your shoe game up!
    2007 VW Passat Variant-Alpine Gray- 19" RS6's, Euro Turn Signal, HID's, VAG Mods, Neuspeed A3 springs, Dewipered
    2007 A3-Silver
    Veteran Member Three Rings felondnb's Avatar
    Jan 12 2008
    London, UK
    yeah... this is defo worth making a sticky! loads of us having been asking the same questions recently!
    Phantom Black Audi A4 2.0T FSi Quattro S-Line Special Edition
    DUH! an Audi
    los angeles, CA
    sweet thread kevin you make me proud sometimes, very little but today is one =D
    Feb 12 2004
    HI.
    Quote Originally Posted by Quattro View Post
    yeah, nice work kevin...
    more to add:
    Quote Originally Posted by SteveMondragon View Post
    H&R 12mm spacers w/longer bolts:
    Here are some pics of the spacers on the car with the 18" S-Line wheels. The first pic is without spacers (lowered on Eibach Sportline springs). The second pic is with the spacers. The visual difference is extremely noticable in person and at different angles. When walking up to the car from the rear, the stance looks wider and more aggressive.
    DUH! an Audi
    los angeles, CA
    you to las, your info >kevin lol
    Senior Member Two Rings vroompshert's Avatar
    Oct 14 2007
    Irvine, Orange County
    Thanks to this thread along with others, I ordered a set of H&R spacers -10mm front/15mm rear.
    Will post pics as soon as they're on! Thanks again!
    '08 Audi A4 2.0T Quattro MT6 / S-Line / Titanium / Navigation/ Convenience Package/ Bluetooth /19" Piano Black Rotiform MIA's w/ Hankook Ventus V12 Evo -235/35/R19/ H&R 10mm rear Spacer/ EVOMS V-Flow/ 6000k HID Fogs/ 6000k D1S
    Veteran Member Three Rings xquizit's Avatar
    Jul 25 2007
    '18 Cadillac Escalade, '19 Mercedes G550, 2018 Audi R8 RWS
    Jacksonville, FL
    Not sure if anyone can give me all the info I need but I have a set of Moven S5R's 19x8.5 Front and 19x9.5 Rear that I want to put on my car I just bought some Falken 452's 235/35/19 Front and 245/35/19 Rear.....not sure if I will need spacers or not but I was thinking of picking up some ECS Tuning ones just in case the 10mm front and 12.5mm rear with both coming with their respective ball seat bolts.....I am wondering if these sizes are fine to where my tire will not be poking out and be nice and flush with the fenders.....as well as if those bolts will do the job and fit perfectly for my wheels....thanks.......
    Car: Ibis White 2014 RS5 4.2 FSI V8
    Mods: Accuair | Brixton Forged M51 20x10.5 | Ecodes | Eventuri Intake | Eventuri Slam Panel | Balance-it Rear Valence |
    Nov 15 2007
    Quote Originally Posted by vroompshert View Post
    Make sure you put some lube on it before you put it on
    Nov 15 2007
    Quote Originally Posted by xquizit View Post
    since is such a big wheel, it sounds like you won't need spacers but just do a test fit. those tires are a bit stretched too.. what's the offset of the rims?
    Jul 25 2007
    Jacksonville, FL
    I believe the offset is +32 Front +35 Rear also what do you mean by a bit stretched?
    Quote Originally Posted by supamannn99 View Post
    Feb 12 2004
    HI.
    you will not need spacers. on all corners i have bbs rg-r 19x8.5 +32 and they are right on the money, no need spacers. 235/35 are ideal for 8.5 wide rim, which i also have in the Michelin PS2s. here's a test fit i did on the front wheel when i first got them:
    Veteran Member Four Rings whitevdub's Avatar
    May 10 2007
    Long island
    nice pics guys...i'm getting bbs LM replicas in 18 inch, i'm definitely goingt o need spacers right?...if i do i was thinking 8mm hubcentric spacers from h and r. has anyone had any problems with them?
    Nov 15 2007
    LAS you should've started this thread.
    Jul 25 2007
    Jacksonville, FL
    Appreciate the info LAS!!!
    Quote Originally Posted by LAS View Post
    Mar 31 2008
    Houston
    Here's a question way out of left field. At what point will your alignment be affected by adding spacers. I know it is not changing the geometry by much but if you add 15mm...20mm....25? Does it make a diff at all?
    Oct 14 2007
    Lube? Please elaborate -thanks!
    Veteran Member Four Rings autoverruckt's Avatar
    Sep 26 2004
    STL
    Anti-seize compound.
    pic compliments of Phrost:
    04 A4 USP 1.8TQ 6MT Silver | GIAC | evo dv
    05 S4 6MT silver
    07 A4 2.0TQ Black | APR93 | Eibach/Koni Sport | oem B7S4 18's
    03 A4 Avant 3.0L Silver | oem B7S4 18's | 10mm rear spacers
    14 A4 2.0TQ Silver | APR93 | S-Line Pkg| Cold Weather Pkg | 12mm rear
    Present:
    20 Q5 Manhattan Gray | Titanium Sport Pkg | Black Optic pkg
    23 S4 Chronos Gray | Premium Plus | S Sport pkg | Sport exhaust
    Oct 14 2007
    Quote Originally Posted by autoverrückt View Post
    Sorry never done this before. so this lube is applied between ?
    Thanks for the help-
    Nov 15 2007
    Alright, so I finally got the correct spacers. I only was able to pick up the rears as the fronts have yet to arrive. I installed them yesterday and took the car for an evening cruise and they drive perfect. Granted they are on the rear, but nonetheless they are good to go.
    Since the hubs are prone to gathering rust, I coated all the surfaces that could eventually become rusty with some white lithium grease. I used a wheel brush to take off the rust that had gathered on the hubs before reassembly.
    Remember 150mm o.d.. The part number is under note #24 on H&R's site.
    be reminded that these were just some really quick pics right after it came off the jacks and before it was driven. I'll get some better today at the Irvine Meet.
    more stuff
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    To the bolts! so they don't get stuck on. It is smart to do it!
    Nov 15 2007
    Quote Originally Posted by Lunar50 View Post
    doubt it
    Senior Member Three Rings Jersey Anthony's Avatar
    Jan 17 2008
    2006 A4 2.0T Q M S-LINE
    Jersey
    what size spacers would i need for 19x8.5 bbs lm reps like a 3 to 5mm right?
    • Automotive Tailors
    • Velocity Motoring
    • D2 Racing
    Senior Member Two Rings Widget's Avatar
    May 22 2007
    '06 A4 S-line, 2.0TQMT - Moro
    New England....
    Stock:
    10mm Front, 10mm Rear
    10mm Front:
    10mm Front, 12.5mm Rear
    I like 8F/10R the best
    Moro Blue Photo Thread
    WTB: | Stasis SS coilovers | 19" Gunmetal RS4 reps PM me...........
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    Maybe someone can give me a definitive answer, running the same setup as me
    19x8.5 wheels ET +35 with 245/35/19 rubber
    widest spacer in the rear and front w/o rubbing on stock suspension. thanks
    Senior Member Two Rings ekaufman's Avatar
    Jul 02 2007
    2008 Black A4 S-line
    Santa Monica
    What about the RS4 reps? If I have 18x8.5 ET58 VMR reps, what size spacer will push me closer to the fender. Anyone running spacers with those wheels?
    Active Member Two Rings sxw2jdxc's Avatar
    Mar 30 2008
    U.S.
    anyone have more before & after pics??
    May 22 2007
    New England....
    Um, look above at my last post... There's a couple different combos for you to compare, as well as stock.
    Apr 15 2007
    WNC
    Anyone with an A4Q put spacers on with stock sport suspension?
    2013 RS5, 2014 Q7
    Nov 15 2007
    i think thats it right there. not very good pictures but still pictures nonetheless
    Sep 26 2004
    STL
    bad phone pic, great angle! It doesn't look this flush but on this day and lighting, it looked mean.
    05 S4 6MT silver
    Present:
