Page 1 of 6 123 ... LastLast
Results 1 to 40 of 239
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    CAT 3658s are in!
    I put them in this morning, and Damn! Boost starts about 2200 rpm making it much more drivable and about 4k, it's like getting launched out of a sling shot until 8500. A video will be soon as I can figured out how to mount the camera so I can drive. Also the exh. is done also, pics will be up soon. Greg, I be calling you shortly on the tuning.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Dec 06 2007
    Re: CAT 3658s are in!
    CAT?? sorry i'm slow! but if a BT can boost from 2200 ur set!
    -Kirk
    BetaAlphaTau Member #58
    Mar 21 2006
    Lakeland, FL.
    Cat is the brand, and I'm BAT 3071r. Also boost will start to fall from 22psi @6500 to about 15psi @8500. So, that tells me the motor needs more boost and I'm more than happy to oblige.
    I'm back bitches!
    Dec 06 2007
    holly smokes! too much power!
    -Kirk
    Mar 21 2006
    Lakeland, FL.
    If you can put it the ground there is no such thing.
    I'm back bitches!
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by dirtybrd View Post
    916-705-0897
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    something that can't be done with a FWD , you have quattro so you are set
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    means you need yourself a bigger turbo
    Mar 21 2006
    Lakeland, FL.
    We'll have to see. I have an issue with the vacuum line between the firewall and brake booster popping out of the grommet. I think a little super glue will do the trick. If I can't keep the boost in the upper RPMs, I guess there will be a 3071r for sale and get a 3076 or a modded GT35.[O_O]
    I'm back bitches!
    Veteran Member Four Rings durfA4's Avatar
    Jan 01 2006
    2012 A7 Stage 2, 2014 Q5 3.0T SLine, 2001 Laser Red S4
    Boston
    An easy way to make a camera mount is a couple pieces of wood sandwiched around the pass headrest posts and a screw for the tripod mount. or some thing like this
    http://www.ae92gts.com/ae92gts_video_mount.html
    And another question could cams be useful on a GTRS set up or should I wait till i go bigger.
    2012 A7 3.0t EPL Stage 2
    2014 Q5 3.0t
    2001 S4 STUKLR tuned
    Mar 21 2006
    Lakeland, FL.
    Thanks and yes, Cat 3651's would be great.
    I'm back bitches!
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    OK Chris... I have a super basic understanding of how the cams works so please school me on what these CAT cams do for you.
    Veteran Member Three Rings Carlitos's Avatar
    Sep 17 2006
    B6 A4 1.8T
    San Juan, PR
    Quote Originally Posted by A4 TSCHUSS View Post
    FWD Hater! (j/k)
    btw, nice setup with the cat!! 2.2k rpm is real low!!
    FlexTuning
    Amulet 1.8TM
    BAT#46
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Any cam codes yet?
    -Doug
    Mar 21 2006
    Lakeland, FL.
    Winston, this is basic as I can put this. Aftermarket cams increase the lift and amount of time the valve is open, allowing in more fuel and air. Doug, I haven't Vag'd it yet.
    I'm back bitches!
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    nice...just one more thing to add to my to do list
    Some fast things and some slow things
    ~Josh~
    Mar 21 2006
    Lakeland, FL.
    Just to let you know, the 3658s will give you a CEL due to unplugging the cam chain tens. The VVT @ idle will cause valve to piston issues, but the 3651's won't.
    I'm back bitches!
    Apr 24 2005
    E55 AMG, CTS-V
    so you are running a cam that gives you issues at idle
    ~David~
    CTS-V 9.6@148
    Mar 21 2006
    Lakeland, FL.
    No, the lift is so high on the exh. cam is so high that the VVT will put the valve into the piston. I'm gonna pull the CEL bulb.
    I'm back bitches!
    the cel bulb is an led. you are going to need a soldering iron.
    the 3651's in my car rock. they really opened up midrange like in your car. glad to hear you got them installed.
    contact via email please.
    Feb 17 2005
    Sarasota, FL
    Put a line reducer in the brake booster line to limit the volume of air movement through the line, it will keep it from popping out of the firewall
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    should not be any air going into the brake booster, somebody has a bad check valve
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by k0mpresd View Post
    No you will not, just a 9V battery and a couple of jumper wires, the LED will fry instantly
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by 400HPA4 View Post
    There is a check valve on the brake booster itself. We have vac lines running directly from the IM to the grommet in the firewall
    Feb 17 2005
    Sarasota, FL
    Explain?
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    The led is rated at 1.7V if red 4V if white, led's must have a resistor series to limit the current. If you touch a 9V battery to the anode and cathode directly, you will fry the LED
    Oct 31 2005
    Virginia
    How hard is it to install cams in our car? How long did it take you dirtybrd?
    ~Josh~
    Jun 11 2005
    Vancouver, BC
    That's what I assumed.
    I do plan to upgrade the cams in the future and I'll try and do a log of a before and after to see how quickly the boost comes on.
    But from your description... having the BAT start spooling at ~2200rpm would be sick.
    Jun 11 2005
    Vancouver, BC
    Fry the LED?
    I've had one explode before by me being lazy and not installing a current limiting resistor.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by mtbrider View Post
    Josh, I know you have your shop but I'm down... its not too hard shouldnt take mroe then a few hours
    - Clint
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by [email protected] View Post
    Fry the LED?
    Bingo! that was with 12 volts most likely, 9v will just fry it.
    Veteran Member Four Rings 20vturbo's Avatar
    Nov 24 2004
    2004 A4 2.1t, 2015 Q5 3.0t
    MOntreal
    no need to fry you can put a resistor in the plug
    Do you have stiffer springs in the motor???
    BetaAlphaTau member #19
    Mar 21 2006
    Lakeland, FL.
    The hose from the firewall to the booster is the one popping off, I think I might just install a check valve on the eng side of the firewall, I have a few laying around at work. The cams took about 1.5 hours to install, on a hot motor no less. I have Ferrera valve springs and titanium retainers. Just make sure to not start the motor for about 30 mins after your done. The lifters need time to settle from having the cams out.
    I'm back bitches!
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    I do not know if you have a panduit gun (zip tie) or not. A nice and tight zip tie should take care of the popping off issue.
    Oct 31 2005
    Virginia
    When are you going to be back in town/MD?
    ~Josh~
    Nov 24 2004
    MOntreal
    I have those springs and retainers also take a look at this picture it shows the exhaust cams oem and revolver...the gear moved on the revolver car was running fine but i was getting the cam code so i removed them..i am now on the stock cams i think the added resistance from the springs and the fact that there are no keys to hold the gear is the cause
    Mar 21 2006
    Lakeland, FL.
    There isn't any room for one, the grommet is flat on that side.
    I'm back bitches!
    Nov 24 2004
    MOntreal
    so what do you think about that
    Mar 21 2006
    Lakeland, FL.
    I'm not sure. I know Bob @ QED is drilling and installing roll pins in the end on all the CAT cams he has and or sells. If this is the case with your cams, then that will be a case with both CAT and Revolvers. I'll Vag. it right now to see. Just checked it and the only cam related code I have is for having the adjuster/tens. unplugged. I thought I would have one for the cam pos. sensor being as the cam isn't where the ECU is saying it should be, get it?
    I'm back bitches!
    Nov 24 2004
    MOntreal
    no mine didnt have that and I am not sure those pins can hold at 8500rpm...Can you do comp test i wanna know how much you have with those cams...Mine was compressing 120psi with the revover cams and the car run fine..with the stock I have 150psi..I can't believe how close I was to destroying the motor
