Results 1 to 3 of 3
    Veteran Member Three Rings darin1274's Avatar
    Dec 28 2007
    2016 VW Passat TSI
    Phx, AZ
    alignment issue for B7 A4
    Oh man....I'm so fustrated! I had my tein suspension installed afew months back and since then have added 19" wheels and tires. I noticed that the right rear has alot of negative camber. To the point that it needs a spacer to make it flush with the fender. the left side isnt that bad...
    I took the car in for an alignment today and here are my numbers:
    LF: RF:
    Camber:-1.3 Camber:-1.2
    Toe:17 Toe:17
    LR: LR:
    Camber:-.5 Camber:-2.3
    Toe: .17 Toe:18
    so you can see why the right rear looks "off". Can anyone offer any help on this? I dont wont to burn through tires here and the dealer says they can bring it back in line for like $350!!! Hello No! This is so fustrating that I ALMOST want to pull off the suspension and just roll stock
    ...step your shoe game up!
    2007 VW Passat Variant-Alpine Gray- 19" RS6's, Euro Turn Signal, HID's, VAG Mods, Neuspeed A3 springs, Dewipered
    2007 A3-Silver
    Veteran Member Three Rings vwong's Avatar
    Apr 03 2006
    '10 S4, '09 335i, '98 Prelude
    Re: alignment issue for B7 A4
    The alignment shop you went to probably doesn't know that the rear camber can be adjusted. Take your car back to them and tell them that the rear camber can be adjusted, or just take the car to a different alignment shop.
    2010 Audi S4 6MT
    2009 BMW 335i Coupe 6MT
    YouTube Channel
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    B8.5 S4, B8 S4, B7 A4A, B6 A4, B5 A4, Q7, 958TT, 955TTS, 997C2S, 996TT...
    Portland, OR
    Quote Originally Posted by vwong View Post
    Agreed.
    Jeremy Williams
    Matrix Integrated Inc.
    www.matrixintegrated.cc
