Results 1 to 13 of 13
    Aug 26 2005
    PSA Max torque rating of 5 speed tip trans..
    According to ZF, the maximum input torque (engine) rating for the 5HP19FLA trans is 420 Nm or ~310 ft*lbf.
    Ref:http://www.zf-group.com/pdf/5HP19FLA.pdf
    Veteran Member Three Rings 9744RR's Avatar
    Sep 01 2005
    2016 A6 3.0T, 2003 A4 1.8T Tip, GTRS Elim, REV0, 440 injectors, ASP front mount, etc Porsche 356
    Re: PSA Max torque rating of 5 speed tip trans..
    Yeah I mentioned that in a post a few months ago. Another member said that it was a mistake on ZF's part. Hopefully it isn't since the 5HP19FLA is used on so many Audi/VW cars with much higher torque ratings than our 1.8T's. I can say with my own personal experience that through all the 3 stages of REVO programming my A4 went through, the tranny has held up well and feels as strong and is holding through the gears as it did day one. What someone needs to do for us is figure out how to break the TCU programming so we can modify the shift points, linepressure, etc... without going into the tranny and beefing up the internals. I feel that our ZF tranny's can hold power mods well especially the GTRS.
    2016 A6 3.0T Stock
    2003 A4 1.8T Q TIP not stock
    Porsche 356 Stock
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Quote Originally Posted by 9744RR View Post
    Have you ever neutral dropped on your car?
    Sep 01 2005
    You do you mean ^^^? Put the car in neutral, rev, then shift to drive? If so, then NO. Becasue I want my tranny to last and this is something stupid that I've never done to any of my personal (automatic) cars, nor will ever do this to launch my cars, and I have no need to, plus I'm too old for this that's why all our cars are automatics now. I've done my time back in the late 1970's to early 1980's revving the crap of my 4 speed (yes 4 speed) cars and later 1980's 5 speed manual tranny cars, dropping hte clutch and launching the s%&t out of them to go fast. Those days are gone and well forgotten.
    2016 A6 3.0T Stock
    Porsche 356 Stock
    Veteran Member Four Rings Audized's Avatar
    Oct 22 2006
    Eh?
    There was a discussion on this long time ago. Somebody pointed out that the torque rating they provided in that ZF manual is incorrect. I hope it's 310 lbs*ft!
    http://www.audizine.com/forum/showthread.php?t=76340
    Aug 26 2005
    Quote Originally Posted by autumn View Post
    I don't know of any information from ZF that says the 420 Nm rating is not correct, stating a different rating is actually right. As knowledgable as many are, the only authority here is ZF. Evidence that this rating is accurate is supported by the fact that this trans is also used by Audi in other models including the 2.7T and 4.3l V8, with earlier applications in A/S4s, A6s and A8s.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    I know that ZF makes some of the best auto trannies around so I wouldn't be surprised if it's underrated.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Registered Member Two Rings
    Feb 07 2006
    ouellette
    I agree, ZF's are a quality trans. BMW's been using them on some models for a long time. T
    Sep 24 2007
    Woodbridge, Ontario
    Thats exactly what I mean. And what im getting at is if the auto will be able to handle a beating as is.
    Oct 22 2006
    Eh?
    That's what I initially thought until I saw this...
    http://www.audizine.com/forum/showpo...0&postcount=20
    and this...
    http://www.zf.com/na/content/media/i...g/5HP19FLA.pdf
    Sep 01 2005
    Quote Originally Posted by audipotential View Post
    Well the tranny itself will last as long if its not abused, just with any other component in a car. Neutral dropping, torque braking will damage the tranny nad wear down the internals, but taking off from a stop from idle should not do harm.
    2016 A6 3.0T Stock
    Porsche 356 Stock
    Sep 01 2005
    I remember that ^^^ thread.
    For me personally, with the way the car has been performing from REVO stg 1 then stg 2 programing(BI program) with race gas being well beyond the 310nm or ~ 230lb of torque, and now with the GTRS, I am led to believe, and it may just be wishful thinking or the Germans are underrating thier designs and/or over designing/engineering, that the tranny is rated at 420nm with maybe a little more room to go. The tranny has not slipped during regular driving and sprited driving.
    2016 A6 3.0T Stock
    Porsche 356 Stock
    Oct 22 2006
    Eh?
    Indeed. I've been on REVO Stage 2 for quite a while. No slipping thus far. Knock on wood.
