Results 1 to 15 of 15
    Veteran Member Four Rings FrankA6's Avatar
    Mar 30 2008
    2004 A6 2.7T, 2012 Volvo S60 R-Design
    Pittsburgh
    32ET offsets , will they work???
    Like it says, will 32ET offsets work on my 04 A6, with it being lowered on Koni FSD+Eibachs, and if they do, will they rub???
    2004 Audi A6 2.7T
    Jun 19 2007
    03 Audi A6, 06 Denali
    Bakersfield, CA
    Re: 32ET offsets , will they work???
    I think it will depend on the tire size more than anything. I have 19x8.5 with a 35 offset, and a 245/35 tire and I only rub on big dips, or bumps. If if were a 235/35 then I don't think that it would even rub. Not too sure what tire size would be good for an 18", but I'm thinking a 235/40/18.
    Get with GIGI, as he just went to an 18" wheel set up. Good luck.....your ride looks great!
    "hit the clutch, the gear, the gas, and I'm gone"-- 50 Cent
    Veteran Member Four Rings Gigi's Avatar
    Jan 23 2006
    2004 Audi A6 2.7T, 1999 Jeep W
    Charlotte, NC
    It also depends on how wide the wheel is 8", 8.5", 9"...? what kind of tires? not all tires are created equal within the same size, soe are wider, some have squarer corners, taller less flexible walls,... all these factors will affect the rub potential :)
    32 et is more ggressive than anything I have had
    I had
    BBS Ck 19 X 8.5 Et35 with 235/35/19 Khumos SPT (seems pretty narrow, round so helps)
    BBS RS GT 19 X 8.5 Et 38 with 245/35/19 Khummos SPT rare run under very hevy loads.
    Hartmann DTM 18 X 8 ET35 with 245/40/18 Goodyear F1 AS UHP a squarer bigger tire with tall no flex walls(RUBBED BIG TIME, had to get them exchanged), then 235/40/18, only rub a little under heavy load (Rare) and rubs the liner only so no biggy.
    BBS RC 17 7.5 ET 43? with 8mm and 15mm spacers, 235/45/17 michelin tires, no rub at all
    I would say that 32 ET will work on a 8" wide rim, and maybe 8.5 even I would definitely stay with 235 tires, 18 diameter if possible and get a rounder, narrower tire... the problem if it is a 8.5 rim is that the wider the more chnace you have to rub against the actual fender edge rather than the liner. Remember that your new suspension is still quite soft , not like my old yellows and H&Rs... so there's more travel, therefore more chance to rub
    Have a great day, Brice
    99 Jeep TJ, 4" lift, Mikey Thompson rims & tires
    http://i157.photobucket.com/albums/t...i/photo-22.jpg
    http://i157.photobucket.com/albums/t...20TJ/Jeep2.jpg
    SOLD: 04 Blue [B]A6 2.7TStage 2 +: Many mods
    Mar 30 2008
    Pittsburgh
    hmm well the wheel is 19x8.5 all around with 32ET, and i was going with 235/35/19"s, but do you think 18's are better, i cant really tell in the pictures, but do they look big on your car in person Gigi?
    2004 Audi A6 2.7T
    Jan 23 2006
    Charlotte, NC
    what wheel are you talking about that you are looking at?
    No my wheels don't look big, but they look about as big as my old 19" RSGTs that had a lip
    Veteran Member Three Rings sempaipaul's Avatar
    Dec 21 2007
    several Porsches
    Gaithersburg MD
    Hey guys...
    check this out.
    http://www.rims-n-tires.com/rt_specs.jsp
    I used this when I was getting rims and tires for my old jag, and the results were perfect fitment.
    Pleay around with the settings it realllly helps out.
    -Paul
    Garage: 03' RS6 (FOR SALE); 16' 328i xDrive Wagon (FOR SALE); 13' X3 M-Sport; 05' Cayenne Turbo, 01' 911 Turbo
    Veteran Member Three Rings Alpinevelo's Avatar
    Dec 28 2006
    06 VW Jetta I5 daily driver bone stock 4 now
    Fountain Hills, AZ
    Quote Originally Posted by FrankA6 View Post
    Frank,
    I could be wrong but your stock wheels are 32 offset. I have the same set and they are .32 Mine are 18 X 8. just to give you an idea... It's hard to figure out if your's are 17's or 18's thats why I like 19's because they definitelly don't look stock. So 32 means that they will be sitting closer to the fender lip. I think that your car will look great with 19's
    C5 A6 2.7T GIAC software Stage 1, EVOMS DV Valves, Cupra spoiler lip, RS4 OEM 18" Wheels.
    Alex
    Mar 30 2008
    Pittsburgh
    Quote Originally Posted by Alpinevelo View Post
    Frank,
    Yeah i think it will to, but im pretty sure im going to get 18 inch, the roads are really bad here. really!
    Oh and my stockies are 17" :(
    2004 Audi A6 2.7T
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    The set of BBS I'm selling originally came off of an A6: 18x8.5 ET32
    Jan 23 2006
    Charlotte, NC
    ^ a wide or narrow body?
    Jan 23 2006
    Charlotte, NC
    and what kind of BS are they? How much? :)
    I might be interested. got pics?
    Jun 11 2005
    Vancouver, BC
    They were from a regular body A6
    Details on the wheels are here: http://www.audizine.com/forum/showthread.php?t=209765
    Jan 23 2006
    Charlotte, NC
    oh cool I ahve those in 17's.
    Is that Tony's wagon?
    Feb 17 2004
    Sterling, VA
    Quote Originally Posted by [email protected] View Post
    Those are the wheels I have on my car.
    18" BBS RC (model 306). They are 18x8.5 ET32. I have lots of room on my car for lowering:
    http://www.audizine.com/forum/showthread.php?t=200803
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Feb 16 2008
    08 Mini, 04 A6 2.7T
    Renton, WA
    um....not to be ignorant or anything but when using the tire calculator mentioned above am I supposed to use -35 or 35 offset?
