Results 1 to 7 of 7
    Veteran Member Three Rings VinNyS4's Avatar
    Nov 07 2007
    New York City
    oil in intercooler hoses
    Ok so tonight i removed my lower intercooler hoses, I first took off the drivers side and in the hose was so oil sitting on the bottom of the hose that looked kind of dense and dark it wasnt that much (not enough to pour out) but it was there. I then removed the passenger side and there was bearly any in the hose. I know it normal to have some oil in the hoses from what other people tell me but does this sound right? The turbos make no whining/drill noise or white smoke and always properly warmed up/cooled down.
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    Re: oil in intercooler hoses
    a little oil is normal but just because the turbo is silent doesnt mean there isnt something wrong. i would just let it go for now seeing as how theres nothing you can do....but maybe thats why i dont have a functioning S4 anymore? but really...what can you do?
    SBSC
    I also like to live dangerously.
    Jun 14 2007
    2000 S4
    Connecticut
    id say youre OK. just wipe it out and if you want check it again in a month or 2 weeks. A LOT isnt good as you stated which is correct, some as you pointed out doesn't strike alarms
    Nov 07 2007
    New York City
    Ok ill clean it out later and check it in a few weeks, I doubt it is anything bad because I just bought the car from a 1 owner with 122k on it and its prob. old oil buillding up because the pervious owner never removed the hoses. But thanks for the help
    Veteran Member Four Rings ny02s4's Avatar
    May 10 2005
    '02 S4 Sold
    LongIsland, NY
    from what i have heard/read on here a little bit of oil is totally normal.
    2008 Grand Cherokee
    2002 Audi S4 - Sold
    i will be back!
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    All journal bearing turbos have slight oil blowby, so its not anything to worry about. My drivers side turbo was pushing out a little more oil than i was comfortable with, so i took off the oil drain on the turbo and it was fairly gunked up. This was probably causing oil to build up in the turbo and causing the extra blowby. The oil drain on the passengers side turbo was perfectly clean, which further proves this was causing the probalem on the drivers side. If youre too worried about it, then you could check the drain lines to make sure they arent getting clogged...other than that its just a waiting game. Good luck man!
    2000 Brilliant Black S4
    -DNA Catback, Piggies, Darintake w/ITG panel filter, 710n's, 034 TBB, 034 F hose, Vast clutch, JHM shifter & bushings, Vogtland/Koni's, Hotchkis Sways, ECS 12.5mm spacers
    2010 Honda Civic Ex Sport Auto
    -Stock daily driver/panty dropper
    2014 Fiat 500 Sport
    -Stock cone dodger for now. Suspension coming soon.
    Veteran Member Four Rings McKennaS4's Avatar
    Sep 25 2006
    2500 dodge ram diesel
    Boston, MA
    search the archives for "oil catch can"
    01 Casa sedan 6MT, sport, cold
