Results 1 to 10 of 10
    Sep 22 2006
    Poulsbo, WA.
    What are possible causes for chronic pinging?
    I need some help. My car has a case of chronic pinging. Here are the details
    2001 a4 1.8T, 75K miles the car will ping when on flat ground and you floor it, it will ping really bad if you have low rpm 2K-2500K in 3rd gear up a slight hill and you floor it. Up shifting in this case helps but it will still ping.
    This is driving me nuts as I can't seem to figure it out. What could be a cause of this I should check out? I am starting to suspect a bad MAF, is there a way to test the MAF? Thanks.
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Re: What are possible causes for chronic pinging?
    Is it pinging, or misfiring?
    Pinging could be running low octane gas,premium only, or too much advanced timing.
    Misfires could be caused by a bad maf, bad plugs, or bad coil pack.
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Veteran Member Three Rings khj677turbo's Avatar
    Dec 25 2007
    Tampa
    Sounds like misfires. Could be a boost leak and you wouldnt even know. You should pressure tests, but first check your plugs, i was dealing with misfires, checked my plugs, and found that one had burnt the resistor (white ceramic part) and the plug was no good, once i changed it the car ran perfect.
    Current: 13 A4 P+ Sport, K04 etc, 18 SQ5
    Gone: 04 A4 1.8t USP 6-speed Avant
    Gone: 00 A4 1.8t K04'd
    Veteran Member Four Rings Nor_Cal_Driver's Avatar
    Jan 03 2005
    14 MkVI, 11 Sienna AWD
    530, California
    Could be plugs.
    13 S4 DSG/Sport Diff/Drive Select
    Gone:
    06 A4 TQM APR tune
    01 A4 TQMS
    01 S4 Sedan MTM tune
    01 S4 Avant APR tune
    02 A4 3.0 Sport
    99 A6 Avant, w/3rd row
    01 A4 Celebration Edition, GIAC tune
    Registered Member Two Rings
    Apr 19 2008
    215 PA
    or the icm is it constant or just maybe when you get on it???
    Jan 17 2006
    Cali
    Quote Originally Posted by Nor_Cal_Driver View Post
    Could be plugs.
    Agreed, I would check these. I had a wicked ping and it turned out to be the plugs.
    Sep 22 2006
    Poulsbo, WA.
    Thanks everyone, sorry for the delay. I did change plugs not too long ago, say 6-9 months ago hoping this would solve this problem. Question - how to know the difference between a misfire sound and the detonation pinging sound?
    I run preium gas, high octane regardless of the cost. I usually get the sound as described by baboom, when I either get on it or give it extra gas up inclines.
    Jan 03 2005
    530, California
    What plugs did you put in? Watch out for gas with 10% ethanol blend too. Are you chipped?
    Gone:
    06 A4 TQM APR tune
    01 A4 TQMS
    02 A4 3.0 Sport
    Sep 22 2006
    Poulsbo, WA.
    Yes chipped, APR. I try to stay away from the 10% ethanol crap as much as possible. As for plugs, honestly can't remember, but nothing cheap, emailed Matrix in Portland for a reconmendation and went with what they suggested.
    Would a bad blow by value have anything to do with it? I am still suspect of the MAF. Can it be cleaned, tested, or ??? How about a new one, where is a good price on a new one?
    Established Member Two Rings mnsirtee's Avatar
    Aug 19 2007
    los angeles
    unplug the MAF and run the car.
