Results 1 to 13 of 13
    Feb 15 2007
    marimont
    Is there a DIY wheel bearing
    Looking for a DIY rear wheel bearing on a 00 avant quattro. Does anyone have a link?
    Oct 25 2006
    '98.5 A4 1.8tqm Sport, '01 MDX
    Oxford, CT
    Re: Is there a DIY wheel bearing
    Are you talking about replacing the actual bearing itself or getting to the point where you can take the bearing to a shop to have it pressed in/out?
    It's not really a job for the DIY without the proper press or renting a Hub Shark.
    Feb 15 2007
    marimont
    Whats the hub shark for? To remove the hub off the axle?
    981CGTS, Cayenne Turbo, '22 A4 Allroad
    Chicago 'burbs
    Quote Originally Posted by solowb5 View Post
    There is also the Sir Tools B90 Master Kit. You can see that in action on Youtube. I bought this a month ago and it is great. You can get som better pricing on it if you search. The video made it look a lot easier than it was for me. But it still wasn't bad.
    2014 A4Q Red w/ black optic black interior
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Check the DIY section on Audiworld. Its actually a pretty easy job. Should take about two hours pending PITA bolts. $60 for the bearing and $30 for Pep Boys to press it for you. Seriously easy.
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Senior Member Three Rings LowSantorin's Avatar
    Oct 19 2007
    Dub State
    Actually just doing this myself this weekend. HAving it pressed in about 6 hours! Anyways here is a write up http://www.audiworld.com/tech/wheel33.shtml Have fun! There is on e bolt you will especially enjoy!
    Senior Member Three Rings A4Shizzle's Avatar
    Mar 19 2006
    San Jose, CA
    It always took me forever to get the control arms re-aligned to the spindle, so I could bolt it back up. Besides that, its pretty straightforward. Not too hard if you have the right tools.
    No time to mod with so many things to fix...
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Quote Originally Posted by ShawFM View Post
    cheapest I found if anyones interested.
    http://www.toolsource.com/wheel-bear...r-p-97151.html
    Chicago 'burbs
    Quote Originally Posted by a4 militant View Post
    Yes that is the place I ordered from. It ships straight from Sir Tools. Had it within 6 days after ordering it.
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    I don't understand buying a tool that is $350 when you can just have it pressed for $30 at pep boys. Even if you replace 4 bearing, its still only $120. Besides my B5 I have never replaced a wheel bearing on any of my other cars.
    Village Idiot!!!
    (\__/)
    (")_(")
    Veteran Member Three Rings b5power's Avatar
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    euroBREED
    ASP Stage 3
    Chicago 'burbs
    Quote Originally Posted by Stampy View Post
    Time: Lee Auto near me turn around time is 24 hours usually. With the tool you have to pull the whole upright, and should have an alignment after reinstalling. With Hub Shark or Sir Tools B90 the upright stays in the car and does not need an alignment after. The tools saves the trips to the auto parts store and for the alignment. For me that is worth the price alone.
    Feb 27 2005
    North Wales, PA
    if you are good with a marker you don't need an alignment. there is an adjustment bolt on the lower control arm. mark the orientation with a white out pen. when you reinstall, rotate the bolt to match up the marks.
