Results 1 to 12 of 12
    Senior Member Three Rings s4me808's Avatar
    Jan 12 2007
    laser red 2001.5 s4
    h1 ewa bound
    Wats wrong with my vacuum
    its my boost I have a vdo boost gauge hooked up which used to work fine but not to long ago it just stop read boost but I can feel it boosting fine even with the vagcom it was reading 20psi but nothin. On the guage I tried a different gauge but same thing we changed the line and same
    any idea
    if if it helps I'm running turbo smart dv and it seems to run a o k
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: Wats wrong with my vacuum
    Quote Originally Posted by s4me808 View Post
    any idea
    Maybe the T-Fitting shat out.
    I had to replace mine for it to work again.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Jun 14 2007
    2000 S4
    Connecticut
    yeah probably something stupid like that. that or your gauge... not too many possible cuases for this one. id go under the hood make sure the T didnt slip out of the hoses, although i would expect if you're normal to feeeel the choppy idle that would occur from that...
    Jan 12 2007
    laser red 2001.5 s4
    h1 ewa bound
    I'll check it out tomarrow
    but it does idle a little choppy
    Wat about the hose that goes to the metal hose doesn t it suppose to be sucking air
    Jun 14 2007
    2000 S4
    Connecticut
    the hose that goes to the metal hose? are you talking the back of the motor driver side near the fuel pressure regulator? idk but take a look i circled the area where MY boost gauge reads pressure and as does many...
    make sure those lines didnt pop off the back of the engine or just check the T, if everything is A OK then replace the T maybe. make sure the lines are tight though, i replaced mine as you can see, all my vacuum hoses for the most part i upgraded since the stock flaky cloth gets old. especially when you cut it in half for the install. i replaced both ends also at the motor
    Jan 12 2007
    laser red 2001.5 s4
    h1 ewa bound
    Thanks bro
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    check to see if the hose popped off the t as well.
    the homebrew'd s4
    Jan 12 2007
    laser red 2001.5 s4
    h1 ewa bound
    wassp found the problem
    audisport was correct but mines looks different I'll try to get a pix up
    btw were can I get that fitting
    Jun 14 2007
    2000 S4
    Connecticut
    +1 AZ Help point. lol, go to any auto store they'll have T fittings of multiple sizes probably in an assortment
    Jan 12 2007
    laser red 2001.5 s4
    h1 ewa bound
    So it doesnt matter wat kind I need because it looks different from yours
    Feb 17 2004
    Sterling, VA
    Most likely, the vacuum line for your fuel pressure regulator (silverish cylinder with vacuum line connection) is 3mm inner diameter. Most auto part stores still only sell American sizes (fractions of an inch). The closest diameter vacuum hose to 3mm is 3/16". So if you get a new vacuum tee fitting, get one that accepts 3/16" on the two sides and something to match the line that feeds your gauge.
    Is this connection totally broken off? If it is, you should stay out of WOT until it's fixed, your fuel pressure regulator needs the pressure that the vacuum line supplies to maintain fuel pressure at high RPMs. Running WOT with a fuel pressure regulator still at base pressure setting (meaning no vacuum hose) will run the car dangerously lean.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Jan 12 2007
    laser red 2001.5 s4
    h1 ewa bound
    Quote Originally Posted by Daft View Post
    thanks bro no wonder It feel slugish at hi rpm top
