Results 1 to 9 of 9
Thread: 2001.5 S4
    Veteran Member Three Rings nateS4's Avatar
    Apr 25 2008
    01.5 Nogaro S4 6spd, 02 GSXR, MkIII TDI
    Baltimore
    2001.5 S4
    Ok, so I think I am about to be an owner of an 01.5 Nogaro S4. The only thing that worries me is it has 120k miles on it. However the guy has a stack of papers of work that had been done at an Audi dealer between him and the other owners. They had the turbos replaced around 80k under warranty and the timing belt/ water pumps done around 90K. The car is immaculate inside and out, its lowered with Bilstein shocks and H&R springs, so the ride is still excellent. It's never been wrecked and very well maintained. It also has GIAC-X installed. I drove it and the turbos sound normal and it rides great, very fast. What I am asking is if there is anything else I should keep in mind or look for before buying this car? Thanks in advance.
    Registered Member Two Rings
    Apr 03 2008
    MD/NC
    Re: 2001.5 S4
    if it drives great then there are no boost leaks which is good. I would try to look at as many of the vacuum/boost pipes as possible (there are a lot). They can tear or dry rot just look at the condition of them. Also check the clutch for slip and obviously there is nothing you can really do but be ready for things like window regulators to go (but that happens at any mileage) and also other electrical like heated seats, onboard computer screen. The thing is I had a a4 and I read about so many things going wrong with different things on peoples cars and luckly maybe one or two of those things went wrong with my car.
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Re: 2001.5 S4
    Be careful of the GIAC. If you pick it up try and get down pipes for the car, it takes away back pressure on the turbos and increases their life.
    Registered Member Three Rings updaboost's Avatar
    Mar 08 2006
    S4, 997 4S & S2000
    Chicago
    Re: 2001.5 S4
    120k is a lot of miles, unless its in great shape for a great price, I'd keep lookin. My 01.5 has 59,000 miles...
    01.5 Nogaro Blue S4, 6sp
    VAST Stage 3 - Piggies - Neuspeed - RS4 Clutch - Samco - Hyperboost DVs - AMS TBB - Stratmosphere SS - Flik Justice/SSR Comps - Vogtland - AWE DTS - H-Sport Sway
    360whp/400wtq
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: 2001.5 S4
    Try to hook up with someone who can scan the car with a VAG-COM. I could probably help if you and the car are in the baltimore area. My fee would be 1/2 hour on your GSXR
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    Re: 2001.5 S4
    psh, my car has 120,000 and hasn't given me any major problems (knock on wood). do not fear my friend!
    the homebrew'd s4
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: 2001.5 S4
    Quote Originally Posted by Overboostin View Post
    .co-signs.
    Apr 25 2008
    Baltimore
    Re: 2001.5 S4
    Quote Originally Posted by grAh4m View Post
    It has "piggies" and a 3 inch cat back. Car purrs like a kitten. The thing is immaculate though, and has lots of service papers.
    Thanks for all the input guys, and I would like to get VAG hooked up to it.
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: 2001.5 S4
    Quote Originally Posted by nateS4 View Post
    My offer still stands...
