Results 1 to 21 of 21
    Established Member Two Rings Rane_kn's Avatar
    Jan 12 2008
    Orlando, FL
    First Dnyo results, oh man...
    OK GIAC (thanks marc) borla exhaust and 710n's with VC gasket leak not sure if anything else would effect the runs
    Stock mode run
    and here's with the pump mode 93 oct
    I talked with the guys there and they said the plugs were igniting the fuel to early for the pistons and suggested a methanol system...I like the idea of the system but is that what is really going on? Thanks guys
    "Shit Happens Wear a Diaper"
    Veteran Member Three Rings BlueturboS4's Avatar
    Feb 21 2006
    2010 s4, 2001 S4, 2002 dakota
    Re: First Dnyo results, oh man...
    ouch, any codes?
    Veteran Member Four Rings lrg8683's Avatar
    Nov 02 2005
    S4
    VA
    why ouch? 278 who? 313 wtq?
    -Luis
    Veteran Member Four Rings AB18's Avatar
    Dec 17 2004
    US
    That dyno is a little on the happy side. A stock S4 should be in the 190awhp to 200awhp. Still, 278awhp is nothing to be dissapointed about it.
    2001 S4 6sp...has a few goodies...and JHM shifted
    Tons of parts for sale..
    GIAC A box ECU for sale-350shipped.
    http://www.audizine.com/forum/showthread.php?t=170072
    Jan 12 2008
    Orlando, FL
    yea I'm not disappointed at all I was happy didn't think I would get that much she did good in both stock and pump. but the 2nd chart has a lot of dips and thats what I'm worried about. I pulled a CEL at autozone and lost the paper but it had something to do with my fuel/air gasket or something along those lines. really not sure I'll have to check again later today.
    Jun 14 2007
    2000 S4
    Connecticut
    i was about to say. good post though i mean i dont want to turn it into a "happy dyno" thread, but for comparision check my thread out, i did 286.7whp/336wtq on a mustang, stage 3- (K04s, 5 bar FPR, stock ICs)
    http://www.audizine.com/forum/showthread.php?t=192448
    Veteran Member Four Rings S-Power's Avatar
    Jan 11 2008
    034 Stage 3
    CA- San Jose
    Damn, your car is as heavy as boat if thats the correct weight on it
    Senior Member Two Rings BB2001S4:Tim's Avatar
    Oct 04 2006
    NY/NJ/CT
    Those dips seem to be throttle cut....possibly.
    Jan 12 2008
    Orlando, FL
    i was about to say....check my thread out, i did 286.7whp/336wtq on a mustang, stage 3- (K04s, 5 bar FPR, stock ICs)
    I see how your read out is way stronger over all. thats what I want, a strong throw all the way to redline. I wanted to dyno mostly to see what was going on inside and how i can fix it. I actually ran into a guy from the shop at work tonight and he said with the audi's and vw's the computer acts different (honda boys). didnt explain why but his girl was hot lol
    S-power- lol yea but atleast its a speed boat lol not to worried about it right now gonna do some weight reduction little by little.
    BB2001S4:Tim - EXPLAIN A LITTLE MORE IN DETAIL PLEASE? LIKE WHAT WOULD CAUSE THIS?
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    damn! that's a whole lot of freaking torque at only 3000rpm!
    TEAM|AXION
    Jan 12 2008
    Orlando, FL
    Quote Originally Posted by speedydragon View Post
    lol my friend drives a civic he calls our cars whip lash, then again its a "happy dyno apparently" but seriously any help with the ?'s much appreciated
    Jan 12 2008
    Orlando, FL
    Ok first off happy mothers day to any moms....if any....
    but weird thing happened guys I went to go check my CEL and when I turned on my car there was none...so I went to work and on the way home it popped up again...just turned it on and no CEL I also noticed a ringing or chingaling noise comming form the engine bay but I cant see any loose bolts and even checked the ones under. Kinda sounds like when a washer is loose between a nut. I'm so kong-fuzed
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    With the car running, press slightly on all the plastics on the car. If it goes away or gets less noticable, then you know where its coming from. Then take off that plastic and look for anything thats loose and tighten it up. A really cool trick for finding engine noises is the old school screwdriver stethoscope technique. Stick the end of a long screwdriver(i find flathead works best) to any part of the engine, then stick your ear to the handle. It only transfers the higher pitched noises, so its really useful for things like this. Slowly work your way around the area thats making the noise until you find the culprit.
    This is assuming that the noise is from a loose bolt/nut. Make sure you check your injectors for loud ticking as well(screwdriver technique is good for this as well).
    2000 Brilliant Black S4
    -DNA Catback, Piggies, Darintake w/ITG panel filter, 710n's, 034 TBB, 034 F hose, Vast clutch, JHM shifter & bushings, Vogtland/Koni's, Hotchkis Sways, ECS 12.5mm spacers
    2010 Honda Civic Ex Sport Auto
    -Stock daily driver/panty dropper
    2014 Fiat 500 Sport
    -Stock cone dodger for now. Suspension coming soon.
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    Quote Originally Posted by sCeRaXn View Post
    Don't mean to be off-topic about with the dyno read, but could you clarify the "loud ticking" coming from the injectors. What do you mean by loud ticking? Is it noticeable without the flathead sethoscope technique? Reason I'm asking is I hear a ticking noise while my engine runs and figured it was normal for a 89K car.
    2015 B8 SQ5
    Click Here
    Past
    Jan 12 2008
    Orlando, FL
    OK so I used the biggest screw driver I could find and a metal rod (not hallow) and after a little while my ear just started feeling funny but I still couldn't centralize a local for the sound. even thought there is the sound I don't feel any difference while driving. which makes me lean towards it just being some loose washer or nut, something generally small. But I posted something about high revs a little bit ago and the sound actually started right after? any suggestions?
    Jan 12 2008
    Orlando, FL
    Looking again at your numbers the HP is the one that is more linear than the rest sort of in the middle right? How did you get your numbers so solid? internals at all or is that all the ko4's? and I'm still unclear about the FATS numbers
    Veteran Member Four Rings HotSauce's Avatar
    Jul 26 2004
    Madison
    Please correct your sig, it's driving me crazy
    Shit happens, wear* a diaper.
    Jan 12 2008
    Orlando, FL
    Quote Originally Posted by HotSauce View Post
    lol at first i was gonna when I did it but I just think it's funny and just cuz it bothers u imma keep it like that.
    Registered User Three Rings Jason@Addict's Avatar
    Oct 14 2007
    Blown RS4
    Woodinville,WA
    Throttle cut?
    Looks like you didn't turn ESP off...
    Jan 12 2008
    Orlando, FL
    Re: Throttle cut?
    Quote Originally Posted by AMD View Post
    I didn't even think of that but would that really effect the stats on a dyno? I know it messes with ur racing.
    Oct 14 2007
    Blown RS4
    Woodinville,WA
    Hells yes...
    absolutely, go back and turn it off.
