Results 1 to 10 of 10
    Veteran Member Four Rings Euro-Tuner's Avatar
    Jan 06 2007
    NH
    Arrow What are you BT guys running for mani brackets?
    What are you guys with BT/BAT setups running for a brace/bracket for your turbo and intake manifold to take some of the pressure off your exhaust studs?
    Pictures and specs please!
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: What are you BT guys running for mani brackets?
    The ram style manifolds setups like Full-race makes does not need a brace. I have never had any issues with the studs holding the manifold to the head and have never used a brace in the 4-5 years I have been running the Full-race manifold.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I do not have any brace and have broken (read: sheared) 8mm studs. I'm going to 10mm studs when I put my 2871R on. Treadstone-style cast manifold.
    EDIT: I was referring to manifold to turbo studs.
    The manifold to head studs are perfectly fine (OEM 8mm I believe).
    -Doug
    Senior Member Three Rings bernB5's Avatar
    Nov 13 2007
    Long Island, NY/ Hartford, CT
    i've never used a turbo-brace on either of the two cars i've owned using the atp mani and 8mm studs.. i wouldn't worry about it as long as you're using quality parts and have flex sections where they need to be, ie: downpipe, ic pipes.
    Old: 97 30r'd A4 ---> headaches
    New: Evo IX MR ---> 354awhp/349tq and couldn't be happier
    BERNSTEINphotography
    Jul 07 2004
    socal
    But your talking about bolts that hold the turbo to the manifold right? Those snap because of the flanges expanding causing the bolts to stretch or just snap. Going with ARP bolts fixed that issue for me.
    For the Full-race setups I recommend using 3/8-16 thread about 1.5- 2" long bolt the turbo to the manifold. You can even tap the manifold flange for one size larger which is what I ended up doing.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Yes.
    I have 10mm studs from 034 Motorsports I will be installing with my 2871R.
    -Doug
    97 A4 2.0TQM
    Rochester, NY
    I do not have a brace on my ATP manifold, and all of the bottom studs broke off. My turbo is rather heavy compared to Garrett units though...
    I see that AutoTech makes stainless studs, which i'm assuming are stronger than stock:
    http://www.autotech.com/prod_engine_downhead.htm
    Jan 06 2007
    NH
    ...I was thinking about doing a brace from the frame rail, but that would be worse than no brace at all, it would push/pull on the mani everytime the engine moved, it needs to attatch from the manifold to the block
    97 A4 2.0TQM
    Rochester, NY
    so...use the hole in the block where the factory brace connected.
    Jan 06 2007
    NH
    thats what I planned.
