Have you regained spark? If you have an ohm spec for your crank position sensor then it's not a Hall Effect, you don't really need a Oscilloscope to verify normal operation then.
If you have a Digital MultiMeter you can do a pinout test at the coilpack/s to see if they're getting the correct power, ground, etc. at that connector. The coils will be fed a digital signal(square wave, on/off) to fire the ignition coils. To verify the digital signal you will need an oscilloscope.
I'm not 100% sure if the ignition control module on a 90 is under the coils or in the PCM. So I couldn't tell ya if there's supposed to be a analog signal or a digital signal to the coils. Easy way to tell, on a coil or coils, there will be a primary and a secondary side. The secondary has the plug wire/s off of it, and the primary has smaller 16-22 gauge wires at the connector. If the Primary conenctor has more than 3 wires in it there's a good chance it has the ignition control module in it.
- I just checked ECS, your coil is $260. Leads me to believe that it has the module in it. That would be the first place I'd be looking.
Now would be a good time to update your secondary ignition. New plugs, wires and possibly that coil. If you haven't already, you'll foul your spark plugs with extended cranking. NTM change your oil. You don't want all that fuel in your oil, it will kill your bearings in a heartbeat, if you let it run like that.
