Results 1 to 20 of 20
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    Went APR Stage 1+ today
    WOW.... The car pulls alot stronger now, the boost comes on smooth and feels like its from the factory. Went with TT225 Injector from Scott at usrt(great service got them in 2 days). Went with the 93 oct. and 100 oct. programs. My boost peaks at about 19psi, then holds at about 15psi and goes down to about 11psi by redline, is that normal?
    Thanks
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    Re: Went APR Stage 1+ today
    you should be spiking higher and holding more
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Nov 04 2007
    Minnesota
    Why is it only spiking at that?
    Current:
    Veteran Member Four Rings a4000's Avatar
    Nov 30 2004
    Pittsburgh
    Don't worry, it'll feel normal(slow) again in a few weeks. It is a great upgrade though and makes the car much more drivable, enjoy! Should spike to ~21. Try a 4th-5th gear pull up a hill, you will probably see more than 19.
    '17 Audi S8 plus // DS1 // E40 // SRM TCU // SRM Flex // SRM Manifolds // SRM 3" Intakes // 034 HPFP // ARM Downpipes // Milltek Non-Res // Ibis // Black with Arras Red Stitching // Dynamic Package // Bang & Olufsen // Black Optics // Driver Assistance // Cold Weather // CETE ASC // 21x9 Ferrada FR8 // PS4S
    '19 Q7 3.0T Prestige // Audi Design Selection Murillo Brown // Luxury // B&O // Black Optics // Adaptive Chassis // Cold Weather // Tow // Night Vision
    Veteran Member Four Rings EuroB6's Avatar
    Nov 24 2005
    2024 Audi Q7 2017 911 GTS
    New Jersey
    that is normal...
    2020 Audi SQ7 PremPlus | Navarra Blue|Black|Black Optic Package| 22” Forged RS wheels incoming…
    2024 Audi Q7 PremPlus|White|Beige|Black Optic Package
    2017 Porsche 911 GTS Black | GTS Interior Package | Numeric shifter | GT3 RS Skirts | Kline SS Headers, Kline 200 Cell Cats, Kline SS Exhaust | Full Car PPF | 20” BC Forged MLE81 | Michelin PS4S |TechArt Springs | Vektor Performance Oil Separator | BMC Air Filter
    Nov 04 2007
    Minnesota
    But is it supposed to drop down to around 11psi by redline??
    Current:
    Veteran Member Three Rings fitch303's Avatar
    Jan 03 2008
    Columbus, Ohio
    hows your clutch
    Nov 04 2007
    Minnesota
    Quote Originally Posted by fitch303 View Post
    hows your clutch
    clutch is holding fine still.... they told me to take it easy on launching, but thats it
    Current:
    Senior Member Two Rings Shi-Fu JaY's Avatar
    Apr 06 2008
    Fontana, SoCal
    im thinking its the little snail (K03) losing its stamina, or in other words...reaching its climax in the higher rpm
    Veteran Member Four Rings IronAudi's Avatar
    Jun 13 2007
    Middletown, CT
    change the DV, that prob some of the problem you have are having, the stock DV wasnt ment to hold 22+ psi there are a ton of options have a look
    2018 C7.5 A65 3.0 S BB Bone Stock - for now.
    2008 B7 A4 2.0 T Brilliant Black|20% Tint|18" RS4 Reps LE|Bone Stock Brand new old Engine.
    Nov 04 2007
    Minnesota
    I do have the forge splitter DV, should i make it tighter, with a couple more turns??
    Current:
    Jan 10 2007
    VA
    ^Probably not needed. But worth a try.
    Give it a little more time to adjust and I bet you'll grab a few more psi of boost. The boost tapering to redline is normal...the K03 runs out of breath.
    Established Member Two Rings ExCarpi's Avatar
    Apr 06 2008
    2005 A4 1.8T 6sp
    Minneapolis, MN
    You can change the spring or add shims. Clicky Clicky
    I think the stock Forge comes with the green spring.
    APR TIP, APR 1+, TT injectors, RaceTec FMIC, JHM Extra short throw shifter (45% reduction), ER Test Pipe, 19" OZ Ultraleggeras, B5S4 Front Calipers, Adam's Rotors with black hubs, Hawk HPS, PSS9 coilovers, Hotchkis Sways, clear corners, tint, Magnaflow Exhaust, Podi pod with SW boost gauge.
    Apr 06 2008
    2005 A4 1.8T 6sp
    Minneapolis, MN
    Opps didn't see you are running the splitter and not the 007. So you don't need the spring kit.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    boost leaks?
    Nov 04 2007
    Minnesota
    no the n75 is stock.... will give it some time to adjust, just got this done this morning
    Current:
    Nov 24 2005
    New Jersey
    no man..the k03 dies out by redline...11psi is fine...usually it's full boost at around 19-21psi, tailing off to 14-15psi and redline is about 11psi....it cant handle any more than that...trust me, you're ok...shift sooner, then, when your RPMs drop, you'll be back in your sweet spot. If you wait til redline, you'll be back up top, where it's starting to tail off. Also, i dont see in your Sig that you have an exhaust. Buy one! that helps.
    Senior Member Two Rings [IX]'s Avatar
    Mar 09 2008
    Florida
    ^^true^^ my 1+ spikes at 23 and holds 15-16 until i go past 4700 rpm and the starts to
    die off to 10-11. Definately shift sooner it helps.
    1+ w/TT225
    Custom Thermal W/ no resonator
    TP
    ER FMIC
    Forge 007
    Just purchased KO4 and Neuspeed Xtreme TIP. Waiting for 034 Mani (ceramic coated) my wife is getting me for my B-Day next month
    <<NO SIG>>
    Nov 04 2007
    Minnesota
    cool, so everything is good..... and yeah exhaust is on the top of my list, so hopefully soon
    Current:
    Mar 09 2008
    Florida
    It has been a battle since my 70+ mph accident in October. But evreything is cool.
    Just the fact that I survived alive and my Audi is till together will keep in them for life
    <<NO SIG>>
