Results 1 to 14 of 14
    Registered Member Two Rings Cosmic Fur's Avatar
    Nov 15 2006
    2001 A4 1.8t
    Toronto, Canada
    Removing the Dash
    I have something that fell deep into the crevice between the windshield and the dash that I'd like to get out. I've tried using sticks, wires, etc, all to no avail, so it looks like I'm going to have to take the dash off to retrieve it.
    1) Is this an extremely lengthy procedure? How many hours of work am I looking at here? Obviously I've never done this before.
    2) I'm looking for instructions on how to do it, I know there are repair manuals out there that tell dealers and mechanics how to disassemble and re-assemble nearly the entire car with helpful diagrams, but I don't know what exactly I'm looking for. ELSA? Bentley? Haynes? EBahn?
    Please help.
    A signature gives you bonus cool points.
    Veteran Member Three Rings fikes's Avatar
    Aug 04 2007
    2001 Audi S4 Sedan
    Perkasie, PA
    Re: Removing the Dash
    Long length processes. I have never done it but its a thick dash with many pieces. best bet is to see if you can first take out the glovebox and see if you cant get your hand back there. Next thing to do it start taking off the center console and see if that gets you closer to it next thing is to start taking off the dash with the bolts under it. I have never seen anywhere that tells you how to do this but there might be one somewhere.
    1997 Audi A4 Sedan 1.8t- Sold
    1999.5 Audi A4 Avant 1.8t- Sold
    2001 Audi S4 Sedan- Current
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    I am pretty sure the cheapy autozone repair books tell how to remove the dash. Might be worth a check
    Nov 15 2006
    2001 A4 1.8t
    Toronto, Canada
    heh, I'm in Canada, we don't have autozone unfortunately.
    Senior Member Two Rings NK2007's Avatar
    Mar 25 2008
    2000 Audi A4
    Ft. Collins & Colorado Springs
    Although I have never removed the dash in an A4, i completely gutted my xterra to clean the previous owner's smoking smell. I didn't have a manual for it, but it was pretty easy. You can probably do it in a day. The hardest part is finding all the screws. Usually there are several screws holding each part in, and once you remove those, there are clips that hold the part in. To get past these, just pop the parts out. Be careful, and make sure to disconnect any wires as you take parts out. Take your time, and take note of different screws, and where they go. Once all the parts (gauges, glovebox, radio, etc) are out, the actual dash should be bolted to a metal support. Remove these bolts, and the dash should come out. This part it is best to have someone to help, although it is possible to do.
    Good luck, and remember, TAKE YOUR TIME to prevent damage to parts.
    Neill
    |00 A4 TQM|K04|Revolver Cams|Greddy FMIC|Custom GIAC|Full Custom Exhaust|OEM RS4|S4 Rear|S4 Interior|HID|
    More to come!
    F.S. Rieger Side Skirts in Silver- will trade for S4
    Mar 25 2008
    2000 Audi A4
    Here you go, this should help!
    This isn't my site, but thanks to the owner!
    http://www.mycarbl0ws.com/audi_b5/Bo...nt%20panel.pdf
    More to come!
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Quit putting your weed/crank/crack/speed/heroin/acid/shrooms on your dash...
    ΜΟΛΩΝ ΛΑΒΕ
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    This is not an Xterra. Not even remotely close. The Japanese make a car easy to work with while the Germans don't see that as something to be bothered with. They just want to make it more intricate and technical. This car comes apart and goes back together in order.
    You have to unbolt the rear of the center console (the big piece under the armrest) and move it back a few inches so the front center console (big piece around the shifter) can be removed. Then drop the steering column and remove the instrument cluster, radio, and hvac controls. Then the directions above apply.
    Jim
    I Do Werk.
    Mar 25 2008
    2000 Audi A4
    Quote Originally Posted by onemoremile View Post
    Did I say it was? I was simply offering some help, from my experience.
    Not even close
    Umm I am pretty sure it is fairly close to what i had to do. The only thing that you mentioned having to do that i didn't is dropping the steering column. Everything else is VERY similar to the xterra.
    And, as you can see in my second reply, i provided a link to the service manual that shows dropping the steering column.
    Yea... most cars do...
    Anyway, Cosmic Fur, hope you got some answers from this thread!
    More to come!
    Mar 09 2004
    nw michigan.
    You're arguing with me about this after I show pictures of the dash I removed? You must be new.
    I owned and operated a car audio store and have done hundreds of installs. Japanese vehicles are dramatically easier to work on than German. Even if the steps are the same the level of detail, fastener selection, number of components, etc. are definitely not. The worst by far are the British cars. I'll never do an install in a Jaguar again. German cars take 50% more time to work on than Japanese while British are easily twice that.
    Jim
    I Do Werk.
    Registered Member Two Rings nyca4tq's Avatar
    Mar 14 2008
    Holy shite 1mm...........!!!!!Thats a lot of shitein work!!!
    F N G here....
    Everything is relative.
    Dec 14 2006
    Halifax, NS, Canada
    I have helped remove an audi dash... having a friend help is really important. Its hard too.
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Apr 19 2008
    215 PA
    what did you drop??dirty magazine??
    if its metal just get a magnet and the dash isn't all that bad really i dropped a silver certificate in mine i think it was a couple bolts and snaps me and a friend did it i think there is a write up somewhere
    Mar 14 2008
    Quote Originally Posted by Cosmic Fur View Post
    Please help.
    Put it on a rotisseri and shake it........Sorry couldnt resist.
    F N G here....
