Results 1 to 13 of 13
    Veteran Member Three Rings scoobycarolan's Avatar
    Nov 02 2007
    Albany, NY
    JHM Sort Shifter & Reverse....
    So I just installed my JH Motorsports Short Shifter.
    Took 5 hours. ~ 4 were all my fault
    Once I got it in and adjusted I realized that Reverse no longer needed a push-down to go into! the extra hour was because I thought R was 1st and I couldn't find 2nd!
    I tried to PM Jason, but his box was full. Basically my new shifter allows me to throw it in R w/o warning! Will the tougher spring stop this? Is my intsall bad? Kinda freaking out here.....
    Aside from, "Man-Up!" any real suggestions?
    Nov 02 2007
    Albany, NY
    Re: JHM Sort Shifter & Reverse....
    Oh! FYI, it DOES make shifting that much better. don't waste your cash on Neuspeed et all. I just need this issue fixed, and honestly its not a deal breaker. I just want it to be perfect for me...
    And on that happy-feely note......
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    although i prefer it to have the push-down feature, man up. :D
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    funny..I'm actually at a Euro Tuning shop with the same issue. I installed it myself but for the first day had no reverse, then finally got all the gears working but the push down reverse thing was eliminated. I got the tech working on it right now, (I actually jumped on the shop's computer to surf these forums for some answers and found this thread!) so I'll let you know what we come up with. Also...did you get the 40% reduction or the 20%?
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
    Veteran Member Four Rings ABanT's Avatar
    Aug 07 2007
    B7 ABT Avant
    Wait, so the JHM one doesn't retain the pushdown to reverse?? I thought it did? Or am I not understanding the posts.
    Nov 12 2007
    Grand Junction, CO
    You can get it. It's an option on the site when you purchase the SSK. You can purchase a spring to keep the pushdown. However....as long as your not downshifting to first on turns, which you never do anyway...I wouldn't really worry about it. Just, when your in first, make sure you can go straight down to second...If you can't...you're in reverse.
    Nov 02 2007
    Albany, NY
    Actually it does have push-down! I emailed Jason @ JHM and he says that i have it installed too far to the right and the 6-speed needs to be perfectly aligned to work correctly.
    Good luck Earhythmic!
    Veteran Member Three Rings matttl16's Avatar
    Feb 25 2007
    2007 audi a4 and 2010 audi a3
    phoenix az
    i had the same problem... the problem is that the shifter is installed upside down... take it out and turn the linkage over and reinstall it and the lock out should be there when finished if installed properly and the correct way
    07 b7 a4 2.0t stage 3
    Active Member Four Rings Goped220's Avatar
    Feb 16 2006
    2023 Audi S4, 2023 Audi A4 & 2016 Subaru Crosstrek
    NY/FL
    Ams All The Way!
    Previous:
    2006 Audi A4 Stage 3 6-Spd, 2011 Audi S4 6-Spd, 2016 Audi S4 6-Spd, 2017 Audi A4 6-Spd Stage 2, 2019 Audi S4 Stage 1, 2019 Benz E450 Stage 1, 2015 STI, 2013 370Z, 2013 Benz GLK, 2014 F-150 FX-4, 2020 Lexus GS350 F-Sport
    Nov 02 2007
    Albany, NY
    so to make matters worse, I adjusted it a little and it was better. I pulled up to a parking spot, shifted and the whole linkage came loose! Luckily I didn't need any more gears. This would have been bad. I was just getting he from a road trip!
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    there isnt really anyway that you could shift it into reverse by accident. bmws dont have the push down and you dont see any freak accidents happening
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    thats because it just grinds then the say F*** thats reverse and they try and find 1st!!
    Nov 02 2007
    Albany, NY
    So I had to order new linkage connection bolts from the dealer. $.46 a piece. I'm going back in to readjust. This time I'm buying the angle thingy. Also checked out the pics from Eddie Man's install of the 40% reduction to see where his is set as a guideline.
    Scooby Carolan: Massive Audio
    2008 Ibis A4 2.0T
    Titanium | S-Line | Sport (20% Tint / Debadged)
    APR 93 octane / JHM SS / EVOms DV / Eurojet PCV
    Koni FSD / Eibach Pro-Kit / RS4 Sway
    **Join the Upstate NY Regional Group!**
