Results 1 to 7 of 7
Thread: Brakes smoking?
    Veteran Member Four Rings sambrody44's Avatar
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Brakes smoking?
    I just pushed my car probably as hard as I've ever pushed it. About half way home, I started smelling brakes. I figured, okay, the brake pads are relatively new, probably still just burning off a little of the new. Well it got worse and worse, then i started to notice fade, lots of it. I had to almost put the pedal to the floor at the last turn. I stop when i get onto my road and check all four corners. I get the the right front and see it is billowing smoke. Not sure how normal that is? But by the time I got home, which is 3 miles uphill with no brakes from where I stopped, all the brake fade was gone and no smoke.
    I'm not looking to get flamed for driving fast by the way, everyone does it occasionally, and I for the most part only do it on roads where I know I'm the only person at risk.
    "set your mindstate free"
    2002 Audi A4 1.8TQM
    Lowered by Stasis SS (finally) On 19" ADR M-Classics.
    Bailey's DV
    Neuspeed Short Shift
    Southbend FE SS Clutch with AWE Flywheel (13lbs lighter then stock)
    Buy my photos here.
    Veteran Member Four Rings FireWire's Avatar
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    Re: Brakes smoking?
    your pads probably caught fire for a bit or was extremely heat soaked. sounds normal
    Typ 8E 03 1.8t Quattro
    2006 600RR
    my photos
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Re: Brakes smoking?
    Thats what I figured. Can anyone second?
    2002 Audi A4 1.8TQM
    Bailey's DV
    Buy my photos here.
    Veteran Member Three Rings 1/4 scale's Avatar
    Mar 03 2004
    North Carolina
    Re: Brakes smoking?
    Quote Originally Posted by sambrody44 View Post
    It could be a seized caliper piston.
    2002 A4 Avant 1.8T • APR +1 • DSMIC • JJ tip • RS4 mounts • SB OFE HD • Apikol snub • B5 S4 binders • 18" Ultraleggeras w/ Conti D/Ws • APR exhaust • APR TBHose • Stasis SS • S4 rear sway • AMS ss • e-codes • Pzwo lip • S4 blades • USP roof spoiler • Apex track studs
    Veteran Member Four Rings audikid66's Avatar
    Jun 13 2007
    Belmar,NJ
    Re: Brakes smoking?
    lol i was racing this g35 coupe and we went to about 115 and then the light was coming up and was red and i slammed the brakes( not hard enuff for abs to kick in but i laid into them nice) i have drilled / slotted front rottors too and my breaks were smoking for a good 3-5 minutes haha...its normal wen u break real hard dont sweat it
    Current car: Stage 3+ 2002 Audi allroad 6 speed
    Past cars:
    imola b6 avant 5spd/URS4 avant Big turbo aan/B7 RS4/k04 b5 Avant /BAT B5 Rally car/B6 Ultrasport/TT / multiple B5 A4 /5 speed ford f-150
    Veteran Member Three Rings quattrotman's Avatar
    Sep 26 2006
    Re: Brakes smoking?
    Haha...man, me thinks you've cooked your first set of pads. If they were newer and not yet broken in properly then you can definitely kiss em goodbye. They will smoke if you really work em but if you feel like you have to stand on the pedal it means they're glazed and are not working properly anymore. They might start squealing now in the next few days too.
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Re: Brakes smoking?
    By the time I got home, I no longer had to stomp on the pedal to get the car to stop. All the fade was gone.
    2002 Audi A4 1.8TQM
    Bailey's DV
    Buy my photos here.
