Results 1 to 18 of 18
    Veteran Member Four Rings jbrown7815's Avatar
    Mar 12 2008
    Portales, NM
    Help with install of my Forge 004
    I'm going from a tt225 DV to this non recirculating BOV
    I've googled all over. I no a4mods has a write up, but this BOV does not recirculate.
    What hose/pipe does this billet plug go in?
    Thanks
    BOV
    Billet PLug
    Thanks
    Senior Member Two Rings a4_1.8t_01's Avatar
    Feb 24 2008
    A4 1.8TQM 01
    Re: Help with install of my Forge 004
    Easy bottom goes into the inter cooler piping/hose. The plug goes into in the airfliter side. Or you take the hose of off the tip and plug it there.
    Unitronic tuned. love it.
    Need any services done in NYC area please PM me. I will diagnose and fix your car. Also do clutch replacements, Timing-belt services, Turbo upgrade/installation, Fluid changes, boost leaks and pretty much anything.
    Mar 12 2008
    Portales, NM
    Quote Originally Posted by a4_1.8t_01 View Post
    I wish knew what you were talking about
    Mar 12 2008
    Portales, NM
    I just can't seem to reach all of it.
    Jan 25 2006
    A4 2.0T
    MD
    Its very simple.... plug up the existing DV hole.
    Feb 24 2008
    A4 1.8TQM 01
    You need to get access from underneeth and look how your dv is connected. You wont be able to get to it from the top.
    Mar 12 2008
    Portales, NM
    Got it. Thing is loud LOL
    Veteran Member Four Rings audikid66's Avatar
    Jun 13 2007
    Belmar,NJ
    do u have a delay inbetween shifts? my hks there is a little delay inbetween shifts cuz the air isnt venting bak into the turbo to keep turbo spooled inbetween shifts
    Current car: Stage 3+ 2002 Audi allroad 6 speed
    Past cars:
    imola b6 avant 5spd/URS4 avant Big turbo aan/B7 RS4/k04 b5 Avant /BAT B5 Rally car/B6 Ultrasport/TT / multiple B5 A4 /5 speed ford f-150
    Buncha motorcycles
    Memphis, TN
    i would be curious to know about the delay as well. i would like a little more noise but not a whole lot, i was thinking about a splitter valve
    APR Stage 2/AWE Intake
    Mar 12 2008
    Portales, NM
    I don't notice any delay b/t my tt225 DV and this BOV.
    Works well, sounds good.
    No CELs, or anything.
    Veteran Member Three Rings d_maniac's Avatar
    Sep 16 2006
    99.5 A4 1.8T Q, 2004 A4 1.8T
    Bronx, New York
    i have this value too, and sometimes its gets annoying with the lag if you slightly left off gas then press it again, the car just sortta studders. Just dont lift off gas to softly and your good.
    Veteran Member Three Rings JustinCase's Avatar
    May 25 2007
    2013 A4, 2011 A4 Avant
    Scranton, Pa
    I dont have any problems with mine at all. I have been running it for about 9 months now.
    -Justin
    2013 A4 Sedan
    2011 A4 Avant
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    dumping metered air FTL
    May 25 2007
    Scranton, Pa
    For .5 seconds when not under power at all.
    -Justin
    2013 A4 Sedan
    2011 A4 Avant
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by Tints View Post
    this is all good for motors that make the power with n/a before they were boosted.
    dumping air that has already been accounted for with your a/f ratios is not good. period. you are causing a rich combustion cycle. again- Fail audi/vw engineers dont use recirculating valves for no reason.
    Veteran Member Four Rings jcg05c's Avatar
    Jun 07 2007
    350z
    orlando
    my hybrid is loud enough i couldnt imagine a bov with intake. Yes rhino ramps and then get under car and hook old up to new.
    19in Privat Netz 10mm front/17.5mm rear
    Apr 1+
    TurboSmart Bov/Dv
    Roof Spoiler
    Jeff Lee Test Pipe
    NS Boost Gauge
    Aug 26 2005
    It's your A4, but I don't understand why advertising the turbo via the dump valve noise is more important than the correct operation of your engine. The measured intake air that is dumped results in fuel mixure control errors and lost performance.
    Veteran Member Three Rings festerfm's Avatar
    Feb 07 2008
    just the a4
    northeast pa
    right.... some people just have different tastes. i personally run a full bov and have no running issues at all. no cel, just a nice sounding whoosh... check this vid.... http://www.youtube.com/watch?v=ZNL5tDJSKNc
