Results 1 to 3 of 3
    Active Member Four Rings EUROTEK//S4's Avatar
    Feb 02 2007
    BMW M3/AUDI S4
    Chicago,IL
    How can you check how much tread is left on a tire?
    How can you check how much tread is left on a tire? thanks
    01' B5 S4 STG.II TIP
    Veteran Member Three Rings Four Play's Avatar
    Mar 15 2007
    is full of shit!
    Texas
    Re: How can you check how much tread is left on a tire?
    Every tire has wear bars that will tell you how close you are to needing a new set of tires. Look in the grooves of the tread for these little bars, and it will give you an idea of where your at in your tires life...
    V8 Touareg - 1G TSI AWD - WRB WRX
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
